Dear Friends,
I was using 8265.NGWMG.DTX1 this wifi moudle in your AGX Som Carrier ,now wifi moudle is going to be obsolute .
Requesting you to help to find new wifi module with compact Xavier AGX Som.
Thanks,
Pooja Ak
Dear Friends,
Thanks,
Pooja Ak
You may find some Wifi mdouel info from Jetson Xavier NX Supported Component List which should also work with AGX Xavier device. Thanks
Dear @kayccc
Thank you for suggested part !
I will check on that
Pooja Ak
Dear @kayccc
Thanks for the response.we checked list and need a wifi moudles which works under -20 to 70 deg.can you please check and suggest any othe wifi moudle.
Kindly help us on this .
Thanks,
Pooja Ak
Sorry that I don’t have answer for this wifi module, you may need to find it by yourown.
Dear @kayccc
Okay Thanku!
Do you have any supported list of wifi modules apart from above mentioned list?
Thanks,
Pooja Ak
Sorry no, you may search forum to see if they use others. Thanks
