I have want to install the r8712u driver. I’m able to to it on a Raspberry but with my Jetson I get an error. I followed this procedure
lsusb
Bus 001 Device 009: ID 0df6:006c Sitecom Europe B.V.
echo 'install r8712u modprobe --ignore-install r8712u ; /bin/echo "0df6 006c" > /sys/bus/usb/drivers/r8712u/new_id' | sudo tee /etc/modprobe.d/r8712u.conf
sudo modprobe -v r8712u
but then I get this error
modprobe: ERROR ../libkmod/libkmod-module.c:809 kmod_module_insert_module() could not find module by name='r8712u'
modprobe: ERROR: could not insert 'r8712u': Function not implemented
sh: 1: cannot create /sys/bus/usb/drivers/r8712u/new_id: DIrecotry nonexistent
modprobe: ERROR ../libkmod/libkmod-module.c:959 command_do() Error running install command for r8712u
modprobe: ERROR: could not insert 'r8712u': Unknown symbol in module, or unknown parameter (see dmesg)
