Hi
I am trying to config the Mediatec WUBM-273ACN (mt7612U) USB wifi device, install the mt7612u driver as follows:
use lsmod we can see the mt7612u module:
Module Size Used by
mt7612u_sta 1237496 1
cfg80211 589351 1 mt7612u_sta
bnep 16562 2
fuse 103841 2
however, the nmcli d status cannot detect the wifi device:
eth0 ethernet connected Wired connection 1
l4tbr0 bridge unmanaged –
dummy0 dummy unmanaged –
rndis0 ethernet unmanaged –
usb0 ethernet unmanaged –
lo loopback unmanaged –
use dmesg can see some errors:
[ 44.123070] usb 1-3.2.1: new high-speed USB device number 8 using tegra-xusb
[ 44.147663] usb 1-3.2.1: New USB device found, idVendor=0e8d, idProduct=7612
[ 44.147733] usb 1-3.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 44.147780] usb 1-3.2.1: Product: 802.11ac WLAN
[ 44.147825] usb 1-3.2.1: Manufacturer: MediaTek Inc.
[ 44.147867] usb 1-3.2.1: SerialNumber: 000000000
[ 44.371608] mt7662u_sta: loading out-of-tree module taints kernel.
[ 44.413771] rtusb init rt2870 —>
[ 44.414212]
=== pAd = ffffff8011001000, size = 1282584 ===
[ 44.414215] driver version: 3.0.0.1 (Oct 27 2020 16:00:07) .
[ 44.414624] ← ERROR in Alloc Bulk buffer for HTTxContext!
[ 44.414627] —> RTMPFreeTxRxRingMemory
[ 44.414663] <— RTMPFreeTxRxRingMemory
[ 44.414665] ERROR mt766u_sta:
[ 44.414667] Failed to allocate memory - TxRxRing
[ 44.414679] ------------[ cut here ]------------
[ 44.414682] kernel BUG at /root/JNN_Linux_for_Tegra/source/public/kernel/kernel-4.9/mm/slub.c:3873!
[ 44.423723] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
any help with this error will be helpful
thanks
