which comes with MediaTek MT7612U. I have downloaded the driver from mediatek site MediaTek | MT7612U
but when I execute $make it is giving me this error
/DPO/include/cfg80211.h:39:49: error: ‘IEEE80211_NUM_BANDS’ undeclared here (not in a function); did you mean ‘IEEE80211_NUM_ACS’?
struct ieee80211_supported_band Cfg80211_bands[IEEE80211_NUM_BANDS];
IEEE80211_NUM_ACS
I checked with $lsusb and it seems the hardware has been installed successfully
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 005: ID 0e8d:7612 MediaTek Inc.
Bus 001 Device 003: ID 0424:2513 Standard Microsystems Corp. 2.0 Hub
Bus 001 Device 009: ID 09cb:4007
Bus 001 Device 008: ID 046d:c534 Logitech, Inc. Unifying Receiver
Bus 001 Device 007: ID 1908:0226 GEMBIRD
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Is there anyone who could successfully install the driver for this or any other WiFi module from MediaTek?
Any help would be appreciated.
I could finally compile the driver after downloading the source code from GitHub - apxii/mt7612u: MT7612U driver for linux.
However, now my issue is when I am trying to load the driver I am getting segmentation fault and this is what $ dmesg is showing:
and when I looked into the source code I found this in ‘/common/cmm_mac_usb.c’
static int RTMPAllocUsbBulkBufStruct(
struct usb_device *udev,
struct urb **ppUrb,
void **ppXBuffer,
INT bufLen,
dma_addr_t *pDmaAddr,
char *pBufName)
*ppUrb = usb_alloc_urb(0, GFP_ATOMIC);
if (*ppUrb == NULL) {
DBGPRINT(RT_DEBUG_ERROR, ("<-- ERROR in Alloc urb struct for %s !\n", pBufName));
return NDIS_STATUS_RESOURCES;
*ppXBuffer = usb_alloc_coherent(udev, bufLen, GFP_ATOMIC, pDmaAddr);
if (*ppXBuffer == NULL) {
DBGPRINT(RT_DEBUG_ERROR, ("<-- ERROR in Alloc Bulk buffer for %s!\n", pBufName));
return NDIS_STATUS_SUCCESS;
So, the bottom line is usb_alloc_coherent() function is failing. I read in some websites in the Internet that setting the coherent_pool=4M somewhere in boot script might solve the issue, but I am not sure where and which script in Jetson I need to edit and append this configuration . Does anyone know how to fix this error?
I finally could build and install the driver and I posted the source code in github if anyone is having the same issue as mine. Here is the link to download the driver.
