Will Mellanox CX-6 LX/DX NIC supported on HP server DL360 Gen10+ ?
The same model NIC is working on DEL R650. Please let me know anything we need to set on HP server to make it work
Thanks,
Susmitha
Thanks,
Susmitha
Hello Gownivalla Susmitha,
Thank you for posting your inquiry on the NVIDIA Developer Forum - Infrastructure and Networking - Section.
We recommend to contact HPE regarding this request as they need to qualify the adapter for this particular system type. I did find the following link which provide the information regarding the current additional options (all, including network adapters) for this system type
Hope this helps.
Thank you and regards,
~NVIDIA Networking Technical Support
Thanks for the response. We are using Mellanox MCX631102AN Mellanox-Lx 25 Gigabit Ethernet adapters and Mellanox MCX623106AN Mellanox-Dx 100 Gigabit Ethernet adapters. As per the HPE document, it supports Mellanox MCX631102AS and Mellanox MCX623106AS. Could you please help me to understand the diff?
Regards,
Susmitha
Mellanox MCX623106AS is Mellanox MCX623106AS-CDAT Ethernet 100Gb 2-port QSFP56 Adapter for HPE
Mellanox MCX631102AS is Mellanox MCX631102AS-ADAT Ethernet 10/25Gb 2-port SFP28 Adapter for HPE
Cheers,
~M.
We would like to know the diff between
