Hm, actually, scew that, that was from a configuration that did not work. Now I got it working somehow (not sure how, I just reinstalled and dpkg-reconfigured the nouveau drivers and xorg itself) but the screens sometimes flicker… Also, in BIOS, I have to have it setup for OPTIMUS, when I set it to NVIDIA, I do not get any display when connected to external screens (but I got mirrored TTY at FullHD on my laptop and all three external screens).
Anyway, the two commnads now are as follows:
Providers: number : 1
Provider 0: id: 0x68 cap: 0x1, Source Output crtcs: 4 outputs: 5 associated providers: 0 name:nouveau
and
Screen 0: minimum 320 x 200, current 5440 x 2560, maximum 8192 x 8192
LVDS-1 connected 1920x1080+640+1440 (0x6e) normal (normal left inverted right x axis y axis) 344mm x 193mm
Identifier: 0x6b
Timestamp: 340850
Subpixel: horizontal rgb
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 1
CRTCs: 1 2 3
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
EDID:
00ffffffffffff0030aeb24000000000
0113010380221378ea2135ad5037aa24
11505400000001010101010101010101
0101010101014c368082703832403c30
aa0058c1100000183f2d808270383240
3c30aa0058c1100000180000000f00d1
0932d109281b190006af5634000000fe
004231353648573031205634200a00d6
scaling mode: Full aspect
supported: Full, Center, Full aspect
non-desktop: 0
range: (0, 1)
link-status: Good
supported: Good, Bad
1920x1080 (0x6e) 139.000MHz -HSync -VSync *current +preferred
h: width 1920 start 1980 end 2028 total 2050 skew 0 clock 67.80KHz
v: height 1080 start 1090 end 1100 total 1130 clock 60.00Hz
1920x1080 (0x6f) 266.500MHz +HSync -VSync DoubleScan
h: width 1920 start 1944 end 1960 total 2000 skew 0 clock 133.25KHz
v: height 1080 start 1081 end 1084 total 1111 clock 59.97Hz
1920x1080 (0x70) 173.000MHz -HSync +VSync
h: width 1920 start 2048 end 2248 total 2576 skew 0 clock 67.16KHz
v: height 1080 start 1083 end 1088 total 1120 clock 59.96Hz
1920x1080 (0x71) 138.500MHz +HSync -VSync
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 66.59KHz
v: height 1080 start 1083 end 1088 total 1111 clock 59.93Hz
1920x1080 (0x72) 115.830MHz -HSync -VSync
h: width 1920 start 1980 end 2028 total 2050 skew 0 clock 56.50KHz
v: height 1080 start 1090 end 1100 total 1130 clock 50.00Hz
1680x1050 (0x73) 146.250MHz -HSync +VSync
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.29KHz
v: height 1050 start 1053 end 1059 total 1089 clock 59.95Hz
1680x1050 (0x74) 119.000MHz +HSync -VSync
h: width 1680 start 1728 end 1760 total 1840 skew 0 clock 64.67KHz
v: height 1050 start 1053 end 1059 total 1080 clock 59.88Hz
1600x1024 (0x75) 103.125MHz +HSync +VSync
h: width 1600 start 1600 end 1656 total 1664 skew 0 clock 61.97KHz
v: height 1024 start 1024 end 1029 total 1030 clock 60.17Hz
1400x1050 (0x76) 122.000MHz +HSync +VSync
h: width 1400 start 1488 end 1640 total 1880 skew 0 clock 64.89KHz
v: height 1050 start 1052 end 1064 total 1082 clock 59.98Hz
1600x900 (0x77) 246.000MHz -HSync +VSync DoubleScan
h: width 1600 start 1728 end 1900 total 2200 skew 0 clock 111.82KHz
v: height 900 start 901 end 904 total 932 clock 59.99Hz
1600x900 (0x78) 186.500MHz +HSync -VSync DoubleScan
h: width 1600 start 1624 end 1640 total 1680 skew 0 clock 111.01KHz
v: height 900 start 901 end 904 total 926 clock 59.94Hz
1600x900 (0x79) 118.250MHz -HSync +VSync
h: width 1600 start 1696 end 1856 total 2112 skew 0 clock 55.99KHz
v: height 900 start 903 end 908 total 934 clock 59.95Hz
1600x900 (0x7a) 97.500MHz +HSync -VSync
h: width 1600 start 1648 end 1680 total 1760 skew 0 clock 55.40KHz
v: height 900 start 903 end 908 total 926 clock 59.82Hz
1280x1024 (0x7b) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1440x900 (0x7c) 106.500MHz -HSync +VSync
h: width 1440 start 1520 end 1672 total 1904 skew 0 clock 55.93KHz
v: height 900 start 903 end 909 total 934 clock 59.89Hz
1400x900 (0x7d) 103.500MHz -HSync +VSync
h: width 1400 start 1480 end 1624 total 1848 skew 0 clock 56.01KHz
v: height 900 start 903 end 913 total 934 clock 59.96Hz
1400x900 (0x7e) 86.500MHz +HSync -VSync
h: width 1400 start 1448 end 1480 total 1560 skew 0 clock 55.45KHz
v: height 900 start 903 end 913 total 926 clock 59.88Hz
1280x960 (0x7f) 108.000MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.00KHz
v: height 960 start 961 end 964 total 1000 clock 60.00Hz
1440x810 (0x80) 198.125MHz -HSync +VSync DoubleScan
h: width 1440 start 1548 end 1704 total 1968 skew 0 clock 100.67KHz
v: height 810 start 811 end 814 total 839 clock 60.00Hz
1440x810 (0x81) 151.875MHz +HSync -VSync DoubleScan
h: width 1440 start 1464 end 1480 total 1520 skew 0 clock 99.92KHz
v: height 810 start 811 end 814 total 833 clock 59.97Hz
1368x768 (0x82) 85.250MHz -HSync +VSync
h: width 1368 start 1440 end 1576 total 1784 skew 0 clock 47.79KHz
v: height 768 start 771 end 781 total 798 clock 59.88Hz
1368x768 (0x83) 72.250MHz +HSync -VSync
h: width 1368 start 1416 end 1448 total 1528 skew 0 clock 47.28KHz
v: height 768 start 771 end 781 total 790 clock 59.85Hz
1360x768 (0x84) 84.750MHz -HSync +VSync
h: width 1360 start 1432 end 1568 total 1776 skew 0 clock 47.72KHz
v: height 768 start 771 end 781 total 798 clock 59.80Hz
1360x768 (0x85) 72.000MHz +HSync -VSync
h: width 1360 start 1408 end 1440 total 1520 skew 0 clock 47.37KHz
v: height 768 start 771 end 781 total 790 clock 59.96Hz
1280x800 (0x86) 174.250MHz -HSync +VSync DoubleScan
h: width 1280 start 1380 end 1516 total 1752 skew 0 clock 99.46KHz
v: height 800 start 801 end 804 total 829 clock 59.99Hz
1280x800 (0x87) 134.250MHz +HSync -VSync DoubleScan
h: width 1280 start 1304 end 1320 total 1360 skew 0 clock 98.71KHz
v: height 800 start 801 end 804 total 823 clock 59.97Hz
1280x800 (0x88) 83.500MHz -HSync +VSync
h: width 1280 start 1352 end 1480 total 1680 skew 0 clock 49.70KHz
v: height 800 start 803 end 809 total 831 clock 59.81Hz
1280x800 (0x89) 71.000MHz +HSync -VSync
h: width 1280 start 1328 end 1360 total 1440 skew 0 clock 49.31KHz
v: height 800 start 803 end 809 total 823 clock 59.91Hz
1152x864 (0x8a) 81.620MHz -HSync +VSync
h: width 1152 start 1216 end 1336 total 1520 skew 0 clock 53.70KHz
v: height 864 start 865 end 868 total 895 clock 60.00Hz
1280x720 (0x8b) 156.125MHz -HSync +VSync DoubleScan
h: width 1280 start 1376 end 1512 total 1744 skew 0 clock 89.52KHz
v: height 720 start 721 end 724 total 746 clock 60.00Hz
1280x720 (0x8c) 120.750MHz +HSync -VSync DoubleScan
h: width 1280 start 1304 end 1320 total 1360 skew 0 clock 88.79KHz
v: height 720 start 721 end 724 total 740 clock 59.99Hz
1280x720 (0x8d) 74.500MHz -HSync +VSync
h: width 1280 start 1344 end 1472 total 1664 skew 0 clock 44.77KHz
v: height 720 start 723 end 728 total 748 clock 59.86Hz
1280x720 (0x8e) 63.750MHz +HSync -VSync
h: width 1280 start 1328 end 1360 total 1440 skew 0 clock 44.27KHz
v: height 720 start 723 end 728 total 741 clock 59.74Hz
1024x768 (0x8f) 133.475MHz -HSync +VSync DoubleScan
h: width 1024 start 1100 end 1212 total 1400 skew 0 clock 95.34KHz
v: height 768 start 768 end 770 total 794 clock 60.04Hz
1024x768 (0x90) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
960x720 (0x91) 117.000MHz -HSync +VSync DoubleScan
h: width 960 start 1024 end 1128 total 1300 skew 0 clock 90.00KHz
v: height 720 start 720 end 722 total 750 clock 60.00Hz
928x696 (0x92) 109.150MHz -HSync +VSync DoubleScan
h: width 928 start 976 end 1088 total 1264 skew 0 clock 86.35KHz
v: height 696 start 696 end 698 total 719 clock 60.05Hz
896x672 (0x93) 102.400MHz -HSync +VSync DoubleScan
h: width 896 start 960 end 1060 total 1224 skew 0 clock 83.66KHz
v: height 672 start 672 end 674 total 697 clock 60.01Hz
1024x576 (0x94) 98.500MHz -HSync +VSync DoubleScan
h: width 1024 start 1092 end 1200 total 1376 skew 0 clock 71.58KHz
v: height 576 start 577 end 580 total 597 clock 59.95Hz
1024x576 (0x95) 78.375MHz +HSync -VSync DoubleScan
h: width 1024 start 1048 end 1064 total 1104 skew 0 clock 70.99KHz
v: height 576 start 577 end 580 total 592 clock 59.96Hz
1024x576 (0x96) 46.500MHz -HSync +VSync
h: width 1024 start 1064 end 1160 total 1296 skew 0 clock 35.88KHz
v: height 576 start 579 end 584 total 599 clock 59.90Hz
1024x576 (0x97) 42.000MHz +HSync -VSync
h: width 1024 start 1072 end 1104 total 1184 skew 0 clock 35.47KHz
v: height 576 start 579 end 584 total 593 clock 59.82Hz
960x600 (0x98) 96.625MHz -HSync +VSync DoubleScan
h: width 960 start 1028 end 1128 total 1296 skew 0 clock 74.56KHz
v: height 600 start 601 end 604 total 622 clock 59.93Hz
960x600 (0x99) 77.000MHz +HSync -VSync DoubleScan
h: width 960 start 984 end 1000 total 1040 skew 0 clock 74.04KHz
v: height 600 start 601 end 604 total 617 clock 60.00Hz
960x540 (0x9a) 86.500MHz -HSync +VSync DoubleScan
h: width 960 start 1024 end 1124 total 1288 skew 0 clock 67.16KHz
v: height 540 start 541 end 544 total 560 clock 59.96Hz
960x540 (0x9b) 69.250MHz +HSync -VSync DoubleScan
h: width 960 start 984 end 1000 total 1040 skew 0 clock 66.59KHz
v: height 540 start 541 end 544 total 555 clock 59.99Hz
960x540 (0x9c) 40.750MHz -HSync +VSync
h: width 960 start 992 end 1088 total 1216 skew 0 clock 33.51KHz
v: height 540 start 543 end 548 total 562 clock 59.63Hz
960x540 (0x9d) 37.250MHz +HSync -VSync
h: width 960 start 1008 end 1040 total 1120 skew 0 clock 33.26KHz
v: height 540 start 543 end 548 total 556 clock 59.82Hz
800x600 (0x9e) 81.000MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 75.00KHz
v: height 600 start 600 end 602 total 625 clock 60.00Hz
800x600 (0x9f) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0xa0) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
840x525 (0xa1) 73.125MHz -HSync +VSync DoubleScan
h: width 840 start 892 end 980 total 1120 skew 0 clock 65.29KHz
v: height 525 start 526 end 529 total 544 clock 60.01Hz
840x525 (0xa2) 59.500MHz +HSync -VSync DoubleScan
h: width 840 start 864 end 880 total 920 skew 0 clock 64.67KHz
v: height 525 start 526 end 529 total 540 clock 59.88Hz
864x486 (0xa3) 32.500MHz -HSync +VSync
h: width 864 start 888 end 968 total 1072 skew 0 clock 30.32KHz
v: height 486 start 489 end 494 total 506 clock 59.92Hz
864x486 (0xa4) 30.500MHz +HSync -VSync
h: width 864 start 912 end 944 total 1024 skew 0 clock 29.79KHz
v: height 486 start 489 end 494 total 500 clock 59.57Hz
800x512 (0xa5) 51.562MHz +HSync +VSync DoubleScan
h: width 800 start 800 end 828 total 832 skew 0 clock 61.97KHz
v: height 512 start 512 end 514 total 515 clock 60.17Hz
700x525 (0xa6) 61.000MHz +HSync +VSync DoubleScan
h: width 700 start 744 end 820 total 940 skew 0 clock 64.89KHz
v: height 525 start 526 end 532 total 541 clock 59.98Hz
800x450 (0xa7) 59.125MHz -HSync +VSync DoubleScan
h: width 800 start 848 end 928 total 1056 skew 0 clock 55.99KHz
v: height 450 start 451 end 454 total 467 clock 59.95Hz
800x450 (0xa8) 48.750MHz +HSync -VSync DoubleScan
h: width 800 start 824 end 840 total 880 skew 0 clock 55.40KHz
v: height 450 start 451 end 454 total 463 clock 59.82Hz
640x512 (0xa9) 54.000MHz +HSync +VSync DoubleScan
h: width 640 start 664 end 720 total 844 skew 0 clock 63.98KHz
v: height 512 start 512 end 514 total 533 clock 60.02Hz
720x450 (0xaa) 53.250MHz -HSync +VSync DoubleScan
h: width 720 start 760 end 836 total 952 skew 0 clock 55.93KHz
v: height 450 start 451 end 454 total 467 clock 59.89Hz
700x450 (0xab) 51.750MHz -HSync +VSync DoubleScan
h: width 700 start 740 end 812 total 924 skew 0 clock 56.01KHz
v: height 450 start 451 end 456 total 467 clock 59.96Hz
700x450 (0xac) 43.250MHz +HSync -VSync DoubleScan
h: width 700 start 724 end 740 total 780 skew 0 clock 55.45KHz
v: height 450 start 451 end 456 total 463 clock 59.88Hz
640x480 (0xad) 54.000MHz +HSync +VSync DoubleScan
h: width 640 start 688 end 744 total 900 skew 0 clock 60.00KHz
v: height 480 start 480 end 482 total 500 clock 60.00Hz
640x480 (0xae) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
720x405 (0xaf) 22.500MHz -HSync +VSync
h: width 720 start 744 end 808 total 896 skew 0 clock 25.11KHz
v: height 405 start 408 end 413 total 422 clock 59.51Hz
720x405 (0xb0) 21.750MHz +HSync -VSync
h: width 720 start 768 end 800 total 880 skew 0 clock 24.72KHz
v: height 405 start 408 end 413 total 419 clock 58.99Hz
684x384 (0xb1) 42.625MHz -HSync +VSync DoubleScan
h: width 684 start 720 end 788 total 892 skew 0 clock 47.79KHz
v: height 384 start 385 end 390 total 399 clock 59.88Hz
684x384 (0xb2) 36.125MHz +HSync -VSync DoubleScan
h: width 684 start 708 end 724 total 764 skew 0 clock 47.28KHz
v: height 384 start 385 end 390 total 395 clock 59.85Hz
680x384 (0xb3) 42.375MHz -HSync +VSync DoubleScan
h: width 680 start 716 end 784 total 888 skew 0 clock 47.72KHz
v: height 384 start 385 end 390 total 399 clock 59.80Hz
680x384 (0xb4) 36.000MHz +HSync -VSync DoubleScan
h: width 680 start 704 end 720 total 760 skew 0 clock 47.37KHz
v: height 384 start 385 end 390 total 395 clock 59.96Hz
640x400 (0xb5) 41.750MHz -HSync +VSync DoubleScan
h: width 640 start 676 end 740 total 840 skew 0 clock 49.70KHz
v: height 400 start 401 end 404 total 415 clock 59.88Hz
640x400 (0xb6) 35.500MHz +HSync -VSync DoubleScan
h: width 640 start 664 end 680 total 720 skew 0 clock 49.31KHz
v: height 400 start 401 end 404 total 411 clock 59.98Hz
576x432 (0xb7) 40.810MHz -HSync +VSync DoubleScan
h: width 576 start 608 end 668 total 760 skew 0 clock 53.70KHz
v: height 432 start 432 end 434 total 447 clock 60.06Hz
640x360 (0xb8) 37.250MHz -HSync +VSync DoubleScan
h: width 640 start 672 end 736 total 832 skew 0 clock 44.77KHz
v: height 360 start 361 end 364 total 374 clock 59.86Hz
640x360 (0xb9) 31.875MHz +HSync -VSync DoubleScan
h: width 640 start 664 end 680 total 720 skew 0 clock 44.27KHz
v: height 360 start 361 end 364 total 370 clock 59.83Hz
640x360 (0xba) 18.000MHz -HSync +VSync
h: width 640 start 664 end 720 total 800 skew 0 clock 22.50KHz
v: height 360 start 363 end 368 total 376 clock 59.84Hz
640x360 (0xbb) 17.750MHz +HSync -VSync
h: width 640 start 688 end 720 total 800 skew 0 clock 22.19KHz
v: height 360 start 363 end 368 total 374 clock 59.32Hz
512x384 (0xbc) 32.500MHz -HSync -VSync DoubleScan
h: width 512 start 524 end 592 total 672 skew 0 clock 48.36KHz
v: height 384 start 385 end 388 total 403 clock 60.00Hz
512x288 (0xbd) 23.250MHz -HSync +VSync DoubleScan
h: width 512 start 532 end 580 total 648 skew 0 clock 35.88KHz
v: height 288 start 289 end 292 total 299 clock 60.00Hz
512x288 (0xbe) 21.000MHz +HSync -VSync DoubleScan
h: width 512 start 536 end 552 total 592 skew 0 clock 35.47KHz
v: height 288 start 289 end 292 total 296 clock 59.92Hz
480x270 (0xbf) 20.375MHz -HSync +VSync DoubleScan
h: width 480 start 496 end 544 total 608 skew 0 clock 33.51KHz
v: height 270 start 271 end 274 total 281 clock 59.63Hz
480x270 (0xc0) 18.625MHz +HSync -VSync DoubleScan
h: width 480 start 504 end 520 total 560 skew 0 clock 33.26KHz
v: height 270 start 271 end 274 total 278 clock 59.82Hz
400x300 (0xc1) 20.000MHz +HSync +VSync DoubleScan
h: width 400 start 420 end 484 total 528 skew 0 clock 37.88KHz
v: height 300 start 300 end 302 total 314 clock 60.32Hz
400x300 (0xc2) 18.000MHz +HSync +VSync DoubleScan
h: width 400 start 412 end 448 total 512 skew 0 clock 35.16KHz
v: height 300 start 300 end 301 total 312 clock 56.34Hz
432x243 (0xc3) 16.250MHz -HSync +VSync DoubleScan
h: width 432 start 444 end 484 total 536 skew 0 clock 30.32KHz
v: height 243 start 244 end 247 total 253 clock 59.92Hz
432x243 (0xc4) 15.250MHz +HSync -VSync DoubleScan
h: width 432 start 456 end 472 total 512 skew 0 clock 29.79KHz
v: height 243 start 244 end 247 total 250 clock 59.57Hz
320x240 (0xc5) 12.587MHz -HSync -VSync DoubleScan
h: width 320 start 328 end 376 total 400 skew 0 clock 31.47KHz
v: height 240 start 245 end 246 total 262 clock 60.05Hz
360x202 (0xc6) 11.250MHz -HSync +VSync DoubleScan
h: width 360 start 372 end 404 total 448 skew 0 clock 25.11KHz
v: height 202 start 204 end 206 total 211 clock 59.51Hz
360x202 (0xc7) 10.875MHz +HSync -VSync DoubleScan
h: width 360 start 384 end 400 total 440 skew 0 clock 24.72KHz
v: height 202 start 204 end 206 total 209 clock 59.13Hz
320x180 (0xc8) 9.000MHz -HSync +VSync DoubleScan
h: width 320 start 332 end 360 total 400 skew 0 clock 22.50KHz
v: height 180 start 181 end 184 total 188 clock 59.84Hz
320x180 (0xc9) 8.875MHz +HSync -VSync DoubleScan
h: width 320 start 344 end 360 total 400 skew 0 clock 22.19KHz
v: height 180 start 181 end 184 total 187 clock 59.32Hz
VGA-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x6c
Timestamp: 340850
Subpixel: unknown
Clones:
CRTCs: 1 2 3
filter:
non-desktop: 0
range: (0, 1)
link-status: Good
LVDS-1-2 disconnected (normal left inverted right x axis y axis)
Identifier: 0x43
Timestamp: 340850
Subpixel: unknown
Clones:
CRTCs: 0 4 5 6
filter:
PRIME Synchronization: 1
supported: 0, 1
dithering depth: auto
supported: auto, 6 bpc, 8 bpc
dithering mode: auto
supported: auto, off, static 2x2, dynamic 2x2, temporal
scaling mode: None
supported: None, Full, Center, Full aspect
color vibrance: 150
range: (0, 200)
vibrant hue: 90
range: (0, 180)
non-desktop: 0
range: (0, 1)
link-status: Good
VGA-1-2 disconnected (normal left inverted right x axis y axis)
Identifier: 0x44
Timestamp: 340850
Subpixel: unknown
Clones:
CRTCs: 0 4 5 6
filter:
supported: 0, 1
scaling mode: None
color vibrance: 150
range: (0, 200)
vibrant hue: 90
range: (0, 180)
non-desktop: 0
range: (0, 1)
link-status: Good
DP-1-1 connected primary 2560x1440+0+0 (0x1a2) normal (normal left inverted right x axis y axis) 597mm x 336mm
Identifier: 0x45
Timestamp: 340850
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 4 5 6
filter:
EDID:
00ffffffffffff0010acea404c383732
1e1c0104a53c22783aee95a3544c9926
0f5054a54b00714fa9408180d1c00101
010101010101565e00a0a0a029503020
350055502100001a000000ff004a3058
594e3837513237384c0a000000fc0044
454c4c205532373137440a20000000fd
00324b1e5819010a202020202020018d
02031cf14f9005040302071601061112
1513141f23091f0783010000023a8018
71382d40582c450055502100001e7e39
00a080381f4030203a0055502100001a
011d007251d01e206e28550055502100
001ebf1600a08038134030203a005550
2100001a000000000000000000000000
00000000000000000000000000000072
PRIME Synchronization: 0
supported: 0, 1
scaling mode: None
color vibrance: 150
range: (0, 200)
vibrant hue: 90
range: (0, 180)
underscan vborder: 0
range: (0, 128)
underscan hborder: 0
range: (0, 128)
underscan: off
supported: auto, off, on
non-desktop: 0
range: (0, 1)
link-status: Good
2560x1440 (0x1a2) 241.500MHz +HSync -VSync *current +preferred
h: width 2560 start 2608 end 2640 total 2720 skew 0 clock 88.79KHz
v: height 1440 start 1443 end 1448 total 1481 clock 59.95Hz
2048x1080 (0x1a3) 147.180MHz +HSync -VSync
h: width 2048 start 2096 end 2128 total 2208 skew 0 clock 66.66KHz
v: height 1080 start 1083 end 1093 total 1111 clock 60.00Hz
2048x1080 (0x1a4) 58.230MHz +HSync -VSync
h: width 2048 start 2096 end 2128 total 2208 skew 0 clock 26.37KHz
v: height 1080 start 1083 end 1093 total 1099 clock 24.00Hz
1920x1080 (0x1a5) 148.500MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x1a6) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1920x1080 (0x1a7) 148.352MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1920x1080i (0x1a8) 74.250MHz +HSync +VSync Interlace
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 33.75KHz
v: height 1080 start 1084 end 1094 total 1125 clock 60.00Hz
1920x1080i (0x1a9) 74.250MHz +HSync +VSync Interlace
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 28.12KHz
v: height 1080 start 1084 end 1094 total 1125 clock 50.00Hz
1920x1080i (0x1aa) 74.176MHz +HSync +VSync Interlace
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 33.72KHz
v: height 1080 start 1084 end 1094 total 1125 clock 59.94Hz
1600x1200 (0x1ab) 162.000MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 75.00KHz
v: height 1200 start 1201 end 1204 total 1250 clock 60.00Hz
1280x1024 (0x1ac) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1152x864 (0x1ad) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1280x720 (0x1ae) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x1af) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1280x720 (0x1b0) 74.176MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1024x768 (0x1b1) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
800x600 (0x1b2) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
720x576 (0x1b3) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x576i (0x1b4) 13.500MHz -HSync -VSync Interlace
h: width 720 start 732 end 795 total 864 skew 0 clock 15.62KHz
v: height 576 start 580 end 586 total 625 clock 50.00Hz
720x480 (0x1b5) 27.027MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.50KHz
v: height 480 start 489 end 495 total 525 clock 60.00Hz
720x480 (0x1b6) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
720x480i (0x1b7) 13.514MHz -HSync -VSync Interlace
h: width 720 start 739 end 801 total 858 skew 0 clock 15.75KHz
v: height 480 start 488 end 494 total 525 clock 60.00Hz
720x480i (0x1b8) 13.500MHz -HSync -VSync Interlace
h: width 720 start 739 end 801 total 858 skew 0 clock 15.73KHz
v: height 480 start 488 end 494 total 525 clock 59.94Hz
640x480 (0x1b9) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x1ba) 25.200MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.50KHz
v: height 480 start 490 end 492 total 525 clock 60.00Hz
720x400 (0x1bb) 28.320MHz -HSync +VSync
h: width 720 start 738 end 846 total 900 skew 0 clock 31.47KHz
v: height 400 start 412 end 414 total 449 clock 70.08Hz
DP-1-2 connected 1440x2560+2560+0 (0x1a2) left (normal left inverted right x axis y axis) 597mm x 336mm
Identifier: 0x46
Timestamp: 340850
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 4
CRTCs: 0 4 5 6
filter:
EDID:
00ffffffffffff0010acea404c333033
594e3837513330334c0a000000fc0044
00324b1e5819010a20202020202001a3
supported: 0, 1
scaling mode: None
color vibrance: 150
range: (0, 200)
vibrant hue: 90
range: (0, 180)
range: (0, 128)
range: (0, 128)
underscan: off
non-desktop: 0
range: (0, 1)
link-status: Good
DP-1-3 connected 1440x2560+4000+0 (0x1a2) right (normal left inverted right x axis y axis) 597mm x 336mm
Identifier: 0x47
Timestamp: 340850
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 5
CRTCs: 0 4 5 6
filter:
EDID:
00ffffffffffff0010acea404c303932
594e3837513239304c0a000000fc0044
00324b1e5819010a2020202020200199
supported: 0, 1
scaling mode: None
color vibrance: 150
range: (0, 200)
vibrant hue: 90
range: (0, 180)
range: (0, 128)
range: (0, 128)
underscan: off
non-desktop: 0
range: (0, 1)
link-status: Good
