Under the nView Properties within the nView Desktop Manager there is a Windows tab. Within the windows tab there is an option to “Open Windows on:” and the choices are:
Default Display
Start Button Display
Next Display
Last Display
I am choosing “Last Display” but some reason my Firefox window continues to open the full length of my two monitor display regardless of where I closed it last. All my other programs seem to be functioning properly (ie Last Display).
Anyone know of why this would happen only in this one program?
Anyone know of conflicts with this setting?
Sort of annoying.
1st make sure the “double arrow” button nview places in the title bar isnt enabled. it spreads the window over the entire dektop and i think it overrides the other settings. it that isnt causing the problem, here is something that helped me with a similar situation.
open the program and resize/relocate it to where you want. leave it open and do the same again. now close the 1st one. open another and resize/relocate it. then close them all. open it again and it should come up in the location and resized as it was when they were all closed.
i was having problems with the window size/location setting gettting all screwed up and this worked for me
