Version: 0.86.20
OS: Windows 11
Docker Desktop: 4.34.3
Repeatable: Was repeatable until I ran out of containers to test against.
Reproduction steps
- Updated to the new workbench 0.86.20.
- Opened existing project
- The spec file is always different because the projects were updated from
specMinorVersion:1tospecMinorVersion:2probably because they were old clones. - Select “undo changes”
- Then I get the “Something when wrong” boo
- Then I go back to the main screen and the project is in red
- Click on the red project and you get “cannot open project” with an option of “delete project”.
- The project is unusable at this point in this current AI Workbench session.
Restart behavior
- If I restart the Workbench and re-open the project, it turns out that the reversion never actually happened and the project is back in the state it was in with the same spec.yaml change that I tried to revert previously
Other Weirdness.
- Prior to reversion, there are open changes and we’re behind in the repo by one pull from the server
- After reversion, there are zero open changes and the repo is no longer one behind the remote GIT repo. This is wrong. The project should still be x versions behind remote.
Bug or Error
Feature Request
Documentation Issue
Other
