AI Workbench APP V0.97.4 issue
If you are reporting a bug or error, consider submitting a Support Bundle to aiworkbench-ea@nvidia.com. This will help us solve your issue more quickly.
After I update the AI workbench windows application from 0.86.20 to 0.97.4 i can not access the AI Workbench remote location(ubuntu on another machine), how can i fix it?
below is the error log:
{“level”:“warn”,“error”:“Process exited with status 1”,“time”:“2025-02-05T22:26:48-08:00”,“message”:“error when checking for remote service status”}
{“level”:“error”,“error”:“ssh: rejected: connect failed (Connection refused)”,“time”:“2025-02-05T22:26:49-08:00”,“message”:“Could not dial localhost:10001”}
{“level”:“error”,“error”:“ssh: rejected: connect failed (Connection refused)”,“time”:“2025-02-05T22:26:50-08:00”,“message”:“Could not dial localhost:10001”}
{“level”:“error”,“error”:“service version (0.53.29) does not match expected version (0.59.1)”,“isWrapped”:false,“isInteractive”:false,“engine”:“json”,“detail”:“detail”,“time”:“2025-02-05T22:26:51-08:00”,“message”:“AI Workbench Server Incompatible”}
Please describe your issue or request: (tick the boxes after creating this topic):
Please tick the appropriate box to help us categorize your post
Bug or Error
Feature Request
Documentation Issue
Other
Hi @Alex.Y, It looks like you also need to update the version of AI Workbench that is installed on the remote machine. Please follow these instructions to update the version of AI Workbench Install, Update, and Uninstall AI Workbench on Ubuntu (Remote) - NVIDIA Docs - let us know if this solves your problem! Thanks, Sophie
Oh, yes, the issue disappeared after i update the remote AI workbench version to the latest 0.97.4, and now it works well now.
thank you.
Fantastic - thanks for confirming that the fix worked. All the best with your AI Workbench project. Sophie
