VPN (Wireguard) and nvwb connection issues
If you are reporting a bug or error, consider submitting a Support Bundle to aiworkbench-ea@nvidia.com. This will help us solve your issue more quickly.
Please describe your issue or request:
I need help!
I’m having great difficulty connecting my NVIDIA Workbench to my Spark via VPN (Wireguard), which connects to my Unifi router (DM SE).
Interestingly, this is not a problem on the local network (without VPN, of course).
With VPN, SSH (Terminal) and Visual Studio Code work, and NVIDIA Sync also allows a connection, but I constantly fail with nvwb.
I’ve already worked with Claude on the ssh_config from sync (ServerAliveInterval 3, ServerAliveCountMax 200, ConnectTimeout 180, ControlMaster no, ControlPersist no, TCPKeepAlive yes, IPQoS lowdelay, Compression yes) to get any timeouts (according to the error message from sync) under control, but unfortunately without success.
Does anyone have any advice on how I can do this? It must be possible to establish a VPN connection with this tool, otherwise it makes no sense!😩
Please tick the appropriate box to help us categorize your post
[ x] Bug or Error
Feature Request
Documentation Issue
Other
Well, since no one is responding to me and NVIDIA’s customer service feels it is not responsible because it only deals with hardware problems, I have painstakingly created a workflow with the help of Sonnet, which I would like to share with you in case anyone else has this problem.
Unfortunately, a pure VPN tunnel via WireGuard does not work with Workbench due to fixed and unchangeable timeouts (hardcoded). Only SSH works when sent through the VPN tunnel on WireGuard.
My requirement was also that I wanted to connect to the Spark server using Workbench Desktop (because I am familiar with the GUI). To do this, however, you have to trick Workbench and configure it in the background (not via the GUI). Incidentally, since Workbench unfortunately has fixed ports, you also have to redirect them, etc.
Here is the solution that works for me (macOS):
Complete Step-by-Step Configuration Guide
This guide provides a working solution for connecting the NVIDIA AI Workbench Desktop App to a remote server through an SSH tunnel over a VPN connection.[1][2]
Use Case
This configuration is ideal when:
  • Direct SSH access to the remote server times out or is unstable
  • VPN connection is available but has keepalive issues
  • You need to access a remote GPU server through corporate VPN
  • VSCode Remote-SSH works but NVIDIA Workbench direct connection fails
Prerequisites
✅ VPN client installed and configured (e.g., WireGuard, OpenVPN)
✅ VPN connection stable enough to maintain basic connectivity
✅ SSH key-based authentication configured (password auth not supported by Workbench)[3]
✅ VSCode with Remote-SSH Extension (recommended for verification)
✅ NVIDIA AI Workbench Desktop App installed on local machine
✅ NVIDIA AI Workbench installed on remote server
Architecture Overview
Local Machine                SSH Tunnel              Remote Server
│             │             │   VPN    │           │              │
│ Workbench   │────────────▶│  Tunnel  │──────────▶│  wb-svc      │
│ Desktop App │             │          │           │  (port 10001)│
│ localhost:  │                                    │ Remote IP:   │
│  - 10005 ───┼────────────────────────────────────▶ 10001       │
│  - 10004 ───┼────────────────────────────────────▶ 8888        │
│  - 10022 ───┼────────────────────────────────────▶ 22          │
Port Mapping:
  • Local 10005 → Remote 10001 (wb-svc Service API)[4]
  • Local 10004 → Remote 8888 (Proxy/Jupyter for applications)[5]
  • Local 10022 → Remote 22 (SSH for fingerprint verification)
Step 1: Connect and Verify VPN
# Connect VPN (method depends on your VPN client)
# Example for WireGuard: Start via GUI or CLI
# Verify connectivity to remote server
ping -c 3 <REMOTE_SERVER_IP>
Expected output: Successful ping responses
⚠️ Critical: Without an active VPN connection, all subsequent steps will fail.
Step 2: Connect VSCode to Remote Server (Verification)
This step verifies that SSH connectivity works through the VPN.[6]
# Open VSCode
# Press Cmd+Shift+P (Mac) or Ctrl+Shift+P (Windows/Linux)
# Type: "Remote-SSH: Connect to Host"
# Select your remote server from the list
Wait until VSCode establishes a stable connection to the remote server.
Step 3: Start wb-svc on Remote Server
In VSCode Terminal (connected to remote server):
# Check if wb-svc is already running
ps aux | grep wb-svc
# If not running, start it:
~/.nvwb/bin/wb-svc serve &
# Verify it's running (should show port 10001)
Expected output:
username    2614  ... wb-svc -quiet -port 10001 serve
Test locally on remote server:
curl http://localhost:10001/v1/version
Expected response:
{"built_on":"Thu Oct 30 17:38:11 UTC 2025","channel":"stable","version":"0.80.4"}
Step 4: Create SSH Tunnel from Local Machine
On your local machine (Terminal/Command Prompt):
# Complete SSH tunnel with 3 port forwards
ssh -i "/path/to/your/ssh_private_key" \
    -o ServerAliveInterval=15 \
    -o ServerAliveCountMax=4 \
    -L 10005:localhost:10001 \
    -L 10004:localhost:8888 \
    -L 10022:localhost:22 \
    -N -f \
    username@<REMOTE_SERVER_IP>
Replace:
  • /path/to/your/ssh_private_key → Your SSH private key path (e.g., ~/.ssh/id_rsa)
  • username → Your username on the remote server
  • <REMOTE_SERVER_IP> → IP address of your remote server
What happens:[7]
  • -L 10005:localhost:10001 → Forward local port 10005 to remote wb-svc service
  • -L 10004:localhost:8888 → Forward local port 10004 to remote proxy/Jupyter
  • -L 10022:localhost:22 → Forward local port 10022 to remote SSH (for Workbench verification)
  • -N -f → Run tunnel in background without shell[8]
  • -o ServerAliveInterval=15 → Send keepalive packets every 15 seconds
  • -o ServerAliveCountMax=4 → Close connection after 4 failed keepalives
Step 5: Verify SSH Tunnel
On your local machine:
# Check if all tunnel ports are active (Unix/Mac/Linux)
lsof -i :10005
lsof -i :10004
lsof -i :10022
# For Windows, use:
# netstat -ano | findstr "10005"
# netstat -ano | findstr "10004"
# netstat -ano | findstr "10022"
# Test wb-svc service through tunnel
curl http://localhost:10005/v1/version
Expected response:
✅ If this works, your tunnel is fully operational!
Step 6: Configure contexts.json
# Create backup if file exists (Unix/Mac/Linux)
cp ~/.nvwb/contexts.json ~/.nvwb/contexts.json.backup
# For Windows:
# copy %USERPROFILE%\.nvwb\contexts.json %USERPROFILE%\.nvwb\contexts.json.backup
# Edit configuration file
nano ~/.nvwb/contexts.json
# For Windows, use Notepad:
# notepad %USERPROFILE%\.nvwb\contexts.json
Complete file content (replace entirely):[9][10]
  "local": {
    "name": "local",
    "description": "My Local Computer",
    "hostname": "localhost",
    "workbenchDir": "/home/username/.nvwb",
    "contextType": "local",
    "contextTypeMetadata": {},
    "sshKeyPath": null,
    "sshUsername": null,
    "sshPort": null,
    "sshFingerprint": null,
    "proxyPort": 10000,
    "servicePort": 10001
  "remote-direct": {
    "name": "remote-direct",
    "description": "Remote server direct SSH",
    "hostname": "<REMOTE_SERVER_IP>",
    "contextType": "manual",
    "sshKeyPath": "/path/to/your/ssh_private_key",
    "sshUsername": "username",
    "sshPort": 22,
    "sshFingerprint": "SHA256:YOUR_SERVER_SSH_FINGERPRINT",
    "proxyPort": 10002,
    "servicePort": 10003
  "remote-tunnel": {
    "name": "remote-tunnel",
    "description": "Remote via SSH Tunnel",
    "hostname": "127.0.0.1",
    "sshPort": 10022,
    "proxyPort": 10004,
    "servicePort": 10005
Replace the following placeholders:
  1. <REMOTE_SERVER_IP> → Your remote server’s IP address (e.g., 192.168.1.100)
  2. /home/username/.nvwb → Remote workbench directory path (keep as-is for Linux servers, or adjust for your setup)
  3. /path/to/your/ssh_private_key → Full path to your SSH private key
    • Mac/Linux: /home/username/.ssh/id_rsa
    • Windows: C:\Users\username\.ssh\id_rsa
  4. username → Your username on the remote server
  5. SHA256:YOUR_SERVER_SSH_FINGERPRINT → SSH fingerprint of your remote server
How to Get SSH Fingerprint
# On your local machine, connect to remote server and note the fingerprint
ssh-keyscan -t ed25519 <REMOTE_SERVER_IP> | ssh-keygen -lf -
# Or from an existing connection:
ssh-keygen -lf /etc/ssh/ssh_host_ed25519_key.pub
Critical configuration details for remote-tunnel:[11]
  • "hostname": "127.0.0.1" ← Must be 127.0.0.1, NOT "localhost" (bypasses Workbench port validation)
  • "sshPort": 10022 ← Tunneled SSH port
  • "servicePort": 10005 ← Tunneled wb-svc port
  • "proxyPort": 10004 ← Tunneled proxy port
  • "contextType": "manual" ← Must be "manual", NOT "local"
Save the file: Ctrl+O, Enter, Ctrl+X (nano) or Ctrl+S (Notepad)
Step 7: Restart NVIDIA AI Workbench Desktop App
Mac/Linux:
# Terminate the app
killall "NVIDIA AI Workbench"
# Clear cache
rm -rf ~/Library/Caches/NVIDIA\ AI\ Workbench/  # Mac
# or
rm -rf ~/.cache/NVIDIA\ AI\ Workbench/           # Linux
# Wait 2 seconds
sleep 2
# Restart the app
open -a "NVIDIA AI Workbench"  # Mac
# or
nvidia-ai-workbench  # Linux
Windows:
# Close app via Task Manager or:
taskkill /F /IM "NVIDIA AI Workbench.exe"
# Clear cache
Remove-Item -Recurse -Force "$env:LOCALAPPDATA\NVIDIA\AI Workbench\Cache"
# Wait 2 seconds
Start-Sleep -Seconds 2
# Restart app from Start Menu or:
Start-Process "C:\Program Files\NVIDIA Corporation\NVIDIA AI Workbench\NVIDIA AI Workbench.exe"
Step 8: Connect to remote-tunnel Location
In the NVIDIA AI Workbench Desktop App:
  1. Open Locations Manager
  2. You should see 3 locations:[12]
    • local (Your local computer)
    • remote-direct (Direct SSH - may timeout over VPN)
    • remote-tunnel (Via SSH Tunnel) ✅
  3. Click on remote-tunnel
  4. If a fingerprint warning appears, accept it
  5. The app should connect successfully! 🎉
Daily Workflow
Morning Setup Routine
1. Connect VPN
# Start your VPN client
# Verify connectivity:
2. Connect VSCode to Remote (Optional, for verification)
# VSCode → Cmd/Ctrl+Shift+P
# "Remote-SSH: Connect to Host" → Select your server
3. Start wb-svc on Remote Server
In VSCode Terminal or direct SSH:
4. Start SSH Tunnel on Local Machine
    -N -f \
5. Verify Tunnel
6. Open NVIDIA AI Workbench Desktop App
# Mac/Linux
# Windows: Use Start Menu or desktop shortcut
7. Select remote-tunnel location and start working! ✅
Troubleshooting
Problem: “Address already in use”
Solution: Kill existing tunnel processes
# Unix/Mac/Linux
lsof -i :10005
kill -9 <PID>
lsof -i :10004
kill -9 <PID>
lsof -i :10022
kill -9 <PID>
# Windows
taskkill /F /PID <PID>
# Restart tunnel (repeat Step 4)
Problem: “Connection reset by peer” when testing curl
Solution: wb-svc is not running on remote server
# SSH to remote server or use VSCode Terminal
# If not running:
Problem: “SSH timeout” when creating tunnel
Solution: VPN connection issue
# Check VPN connectivity
# If timeout: Reconnect VPN
# Ensure VPN routes include your remote server's subnet
Problem: “Failed to get context SSH fingerprints”
Solution: Deactivate context and restart app[13]
# Deactivate context via CLI
~/.nvwb/bin/nvwb deactivate remote-tunnel --shutdown
# Restart app
rm -rf ~/Library/Caches/NVIDIA\ AI\ Workbench/  # Mac/Linux
Problem: Tunnel disconnects after 1-2 minutes
Solution A: Use autossh for automatic reconnection (Recommended)
# Install autossh
# Mac: brew install autossh
# Linux: sudo apt install autossh
# Windows: Use Windows Subsystem for Linux (WSL)
# Start auto-reconnecting tunnel
autossh -M 0 \
    -o "ServerAliveInterval 30" \
    -o "ServerAliveCountMax 3" \
    -o "ExitOnForwardFailure=yes" \
    -N -f \
Solution B: Create manual reconnection script
Create file: tunnel-auto-reconnect.sh
#!/bin/bash
while true; do
  echo "$(date): Starting tunnel..."
      -o ExitOnForwardFailure=yes \
      -N \
  echo "$(date): Tunnel disconnected, reconnecting in 5 seconds..."
  sleep 5
done
Make executable and run:
chmod +x tunnel-auto-reconnect.sh
./tunnel-auto-reconnect.sh &
Problem: Invalid local context error
Error: “the proxy port and service port must be 10000 and 10001”
Solution: Ensure hostname is set to "127.0.0.1" (not "localhost") in contexts.json[14]
Port Reference Table
Local Port Remote Port Purpose
10005 10001 wb-svc Service API [15]
10004 8888 Proxy/Jupyter for applications [16]
10022 22 SSH for fingerprint verification
Summary: What Works
✅ VPN Connection - Base connectivity to remote server
✅ SSH Key Authentication - Required by Workbench[17]
✅ 3-Port SSH Tunnel - Service (10005), Proxy (10004), SSH (10022)
✅ contexts.json Configuration - remote-tunnel context with hostname: 127.0.0.1
✅ Desktop App - Uses remote-tunnel location through tunnel
✅ wb-svc Service - Runs on remote server port 10001
Limitations
⚠️ Tunnel may disconnect - VPN keepalive issues (use autossh for auto-reconnection)
⚠️ Manual setup required - Daily VPN + Tunnel + wb-svc startup needed
⚠️ VSCode more stable - Consider using VSCode Remote-SSH for longer development sessions
Additional Resources
This configuration provides a reliable workaround for accessing NVIDIA AI Workbench on remote GPU servers through unstable VPN connections! 🚀
[21][22][23][24]
  1. Remote Locations — NVIDIA AI Workbench User Guide ↩︎
  2. Frequently Asked Questions for AI Workbench Locations — NVIDIA AI Workbench User Guide ↩︎
  3. Remote Locations — NVIDIA AI Workbench User Guide ↩︎
  4. Remote Locations — NVIDIA AI Workbench User Guide ↩︎
  5. Frequently Asked Questions for AI Workbench Locations — NVIDIA AI Workbench User Guide ↩︎
  6. ↩︎
  7. Securing Network Traffic With SSH Tunnels | Information Security Office ↩︎
  8. Offensive Security Guide to SSH Tunnels and Proxies - SpecterOps ↩︎
  9. Frequently Asked Questions for AI Workbench Locations — NVIDIA AI Workbench User Guide ↩︎
  10. Remote Locations — NVIDIA AI Workbench User Guide ↩︎
  11. Remote Locations — NVIDIA AI Workbench User Guide ↩︎
  12. Frequently Asked Questions for AI Workbench Locations — NVIDIA AI Workbench User Guide ↩︎
  13. Remote Locations — NVIDIA AI Workbench User Guide ↩︎
  14. Remote Locations — NVIDIA AI Workbench User Guide ↩︎
  15. Remote Locations — NVIDIA AI Workbench User Guide ↩︎
  16. Frequently Asked Questions for AI Workbench Locations — NVIDIA AI Workbench User Guide ↩︎
  17. Remote Locations — NVIDIA AI Workbench User Guide ↩︎
  18. Remote Locations — NVIDIA AI Workbench User Guide ↩︎
  19. Securing Network Traffic With SSH Tunnels | Information Security Office ↩︎
  20. Setting up a Remote Development Environment with Windows Server 2019 ↩︎
  21. Develop from Anywhere: How to Set Up a Remote Development Server ↩︎
  22. NVIDIA AI Workbench — RAPIDS Deployment Documentation documentation ↩︎
  23. GitHub - NVIDIA/nim-anywhere: Accelerate your Gen AI with NVIDIA NIM and NVIDIA AI Workbench ↩︎
  24. Setup a Remote NVIDIA AI Workbench Node using EC2 | Aurelio AI ↩︎
howdy - apologies for not getting back to you.
wasn’t aware that the fixed ports like this would cause issues.
i will have engineering team look at this and how you solved it (nicely btw) and see what the permanent fix is.
Thanks for coming back to this!
I just wanted to point out that the problem is not fundamentally caused by the fixed ports.
I originally just wanted to connect nvwb desktop version to my spark via wireguard (or openvpn), and that was the beginning of the “drama.”
After countless configuration changes on both the local desktop and the spark, Claude and I tried to get the timeout problem under control. We tried so many things, but nothing worked, and the final conclusion was that there seems to be a hardcoded timeout (of approx. 107 sec) that could not be circumvented by configuration changes to the keepalives, etc. on the computer/server.
That’s why I came up with the idea of using additional SSH tunnels, which for some reason run stably (in the WireGuard tunnel).
This then led to the problem with the ports that you mentioned.
In my opinion, the goal for the technical team would be to allow a simple connection via WireGuard with the desktop program, then the rest would not be necessary.
Got it. Thanks for the clarification.
Time outs are… a hard problem to solve deterministically.
We will go over this internally and I will get back to you with a fix approach/date.
