Hi all,
In my research group we are working on simulating an omnidirectional base on Isaac Sim for RL training. So far I am experiencing issues when using GPU pipeline, in particular the robot seems to merge with the ground plane. Here is what happens:
When using CPU pipeline, the contact are computed correctly:
The model of the wheels comes from O3dyn, so nothing new.
Here is the script that I use to load the usd (Also in the attached zip)
from omni.isaac.kit import SimulationApp
import os
import torch
USE_GPU_PIPELINE = True
ASSET_PATH = "minimum_robot.usd"
def main():
exp_path = os.environ["EXP_PATH"]
simulation_app = SimulationApp({"headless": False, "enable_livestream": False},
experience=f'{exp_path}/omni.isaac.sim.python.kit')
from omni.isaac.core import World
from omni.isaac.core.articulations import ArticulationView
from omni.isaac.core.utils.stage import add_reference_to_stage
import numpy as np
from omni.isaac.core.objects import GroundPlane
import omni.isaac.core.utils.prims as prim_utils
sim_params = {'gravity': [0.0, 0.0, -9.81],
'dt': 1.0/60.0,
'rendering_dt': 1.0/60.0,
'substeps': 1,
'use_gpu_pipeline': USE_GPU_PIPELINE,
'add_ground_plane': False,
'add_distant_light': False,
'use_fabric': True,
'enable_scene_query_support': True,
'enable_cameras': False,
'disable_contact_processing': False,
'default_physics_material': {'static_friction': 1.0, 'dynamic_friction': 1.0, 'restitution': 0.0},
'enable_viewport': True,
'sim_device': 'cuda:0',
'gpu_found_lost_aggregate_pairs_capacity': 11368,
if sim_params["use_gpu_pipeline"]:
sim_params["device"] = "cuda:0"
else:
sim_params["device"] = "cpu"
my_world = World(stage_units_in_meters=1.0, sim_params=sim_params,
backend='torch',
device =sim_params["device"])
prim_path = "/World/mobile_base"
add_reference_to_stage(usd_path=ASSET_PATH, prim_path=prim_path)
robot_view = ArticulationView(prim_paths_expr="/World/mobile_base/base_link",
translations=torch.tensor([0.0, 0.0, 0.1]).reshape(1,3).to(sim_params["device"]))
my_world.scene.add(robot_view)
plane = GroundPlane(prim_path="/World/GroundPlane", z_position=0)
light_1 = prim_utils.create_prim(
"/World/Light_1",
"DistantLight",
orientation=[0.65,0.27, 0.27, 0.65],
my_world.reset()
while simulation_app.is_running():
my_world.step(render=True)
simulation_app.close()
if __name__ == "__main__":
main()
So far the script is reproducible in isaac 2023.1.1, while in isaac4.2 or 4.1 the simulation is not even able to start.
I attach here this same script with the usd file:
GPU_collisions_issue_MRE.zip (7.4 MB)
My setup:
- Ubuntu 20.04
- RTX 4090
- Driver 550.54.14
- CUDA 12.4
I think the issue is something related with GPU buffers, I tried some tuning but I was not able to make it work. Also I think this is somewhat related to this issue.
We also tried removing the collision meshes (there are 5 spheres for each rollers) and use convex hull on the visual meshes of the rollers. This kinda works and the collision are goo, but the behaviour when the wheels move is way off, the robot vibrates and “jump” just too much.
Let me know if there is anything or any information that might be useful to solve this issue.
Simone
