We’re trying to bring up camera system with Xavier and run into issue that Xavier doesn’t seem to receive valid CSI-2 frames (thus cannot display video stream). However, when connecting camera CSI-2 to MIPI analyzer, it can capture correct 1080p image. Probing the signals on clock lane and 4 data lanes on Xavier shows no anomaly.
Below is top part of the trace log. Can you please help to tell what’s wrong with our setup? Thanks.
kworker/0:3-1733 [000] .... 271.107380: rtos_queue_peek_from_isr_failed: tstamp:8737239558 queue:0x0bcbcf78
kworker/0:3-1733 [000] .... 271.107393: rtcpu_start: tstamp:8737243333
kworker/0:3-1733 [000] .... 271.107397: rtos_queue_send_from_isr_failed: tstamp:8737356608 queue:0x0bcb41f8
kworker/0:3-1733 [000] .... 271.107398: rtos_queue_send_from_isr_failed: tstamp:8737356831 queue:0x0bcb8a60
kworker/0:3-1733 [000] .... 271.107400: rtos_queue_send_from_isr_failed: tstamp:8737357051 queue:0x0bcba5e0
kworker/0:3-1733 [000] .... 271.107401: rtos_queue_send_from_isr_failed: tstamp:8737357271 queue:0x0bcbb3a0
kworker/0:3-1733 [000] .... 271.107403: rtos_queue_send_from_isr_failed: tstamp:8737357491 queue:0x0bcbc160
kworker/0:3-1733 [000] .... 271.107405: rtcpu_string: tstamp:8737358159 id:0x04010000 str:"Configuring ISP GoS.
kworker/0:3-1733 [000] … 271.107450: rtcpu_string: tstamp:8737358429 id:0x04010000 str:" VM GOS[#0] addr=0xe4900000
kworker/0:3-1733 [000] … 271.107462: rtcpu_string: tstamp:8737358759 id:0x04010000 str:" VM GOS[#1] addr=0xe4901000
kworker/0:3-1733 [000] … 271.107472: rtcpu_string: tstamp:8737359130 id:0x04010000 str:" VM GOS[#2] addr=0xe4902000
kworker/0:3-1733 [000] … 271.107481: rtcpu_string: tstamp:8737359437 id:0x04010000 str:" VM GOS[#3] addr=0xe4903000
kworker/0:3-1733 [000] … 271.107496: rtcpu_string: tstamp:8737359747 id:0x04010000 str:" VM GOS[#4] addr=0xe4904000
kworker/0:3-1733 [000] … 271.107506: rtcpu_string: tstamp:8737360057 id:0x04010000 str:" VM GOS[#5] addr=0xe4905000
kworker/0:3-1733 [000] … 271.107515: rtcpu_string: tstamp:8737378461 id:0x04010000 str:“WARNING: t194/isp5.c:901 [config_channel] “”
kworker/0:3-1733 [000] … 271.107517: rtcpu_string: tstamp:8737378947 id:0x04010000 str:“All error notifications not enabled: correctable”
kworker/0:3-1733 [000] … 271.107519: rtcpu_string: tstamp:8737379142 id:0x04010000 str:”=0x00 uncorrectable=0x00"
kworker/0:3-1733 [000] … 271.107521: rtcpu_string: tstamp:8737379427 id:0x04010000 str:""
kworker/0:1-1165 [000] … 271.275439: rtos_queue_peek_from_isr_failed: tstamp:8742240065 queue:0x0bcbcf78
nvargus-daemon-8053 [000] … 271.437822: tegra_channel_open: vi-output, imx477 30-0010
nvargus-daemon-8053 [000] … 271.437846: tegra_channel_set_power: imx477 30-0010 : 0x1
nvargus-daemon-8053 [000] … 271.437884: camera_common_s_power: status : 0x1
nvargus-daemon-8053 [000] … 271.438866: tegra_channel_set_power: 15a00000.nvcsi–4 : 0x1
nvargus-daemon-8053 [000] … 271.438872: csi_s_power: enable : 0x1
nvargus-daemon-8053 [000] … 271.439117: tegra_channel_close: vi-output, imx477 30-0010
nvargus-daemon-8053 [000] … 271.439124: tegra_channel_set_power: imx477 30-0010 : 0x0
nvargus-daemon-8053 [000] … 271.439145: camera_common_s_power: status : 0x0
nvargus-daemon-8053 [000] … 271.439382: tegra_channel_set_power: 15a00000.nvcsi–4 : 0x0
nvargus-daemon-8053 [000] … 271.439384: csi_s_power: enable : 0x0
nvargus-daemon-8053 [000] … 271.440717: tegra_channel_open: vi-output, imx477 31-0010
nvargus-daemon-8053 [000] … 271.440726: tegra_channel_set_power: imx477 31-0010 : 0x1
nvargus-daemon-8053 [000] … 271.440784: camera_common_s_power: status : 0x1
nvargus-daemon-8053 [000] … 271.441625: tegra_channel_set_power: 15a00000.nvcsi–3 : 0x1
nvargus-daemon-8053 [000] … 271.441629: csi_s_power: enable : 0x1
nvargus-daemon-8053 [000] … 271.441821: tegra_channel_close: vi-output, imx477 31-0010
nvargus-daemon-8053 [000] … 271.441825: tegra_channel_set_power: imx477 31-0010 : 0x0
nvargus-daemon-8053 [000] … 271.441872: camera_common_s_power: status : 0x0
nvargus-daemon-8053 [000] … 271.442055: tegra_channel_set_power: 15a00000.nvcsi–3 : 0x0
nvargus-daemon-8053 [000] … 271.442058: csi_s_power: enable : 0x0
nvargus-daemon-8053 [000] … 271.443111: tegra_channel_open: vi-output, imx477 32-0010
nvargus-daemon-8053 [000] … 271.443147: tegra_channel_set_power: imx477 32-0010 : 0x1
nvargus-daemon-8053 [000] … 271.443215: camera_common_s_power: status : 0x1
kworker/0:1-1165 [000] … 271.443427: rtos_queue_peek_from_isr_failed: tstamp:8747239991 queue:0x0bcbcf78
