So I was able to get SDKManager to install Jetpack 5.0.2 to NVMe SSD on Xavier NX… it did not work on several tries… but then I switched to a VM running 18.04 and it worked.
However, while it now works… for some reason, the onboard eMMC does not show up as a device. I am using a SeeedStudio carrier board that does not have and SDCard interface.
After the flash, the JetPack seems to work okay, but I am seeing what I think are odd things in the configuration. Running lsblk shows a number of portions on the NVMe device as follows:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 16M 1 loop
zram0 251:0 0 1.8G 0 disk [SWAP]
zram1 251:1 0 1.8G 0 disk [SWAP]
zram2 251:2 0 1.8G 0 disk [SWAP]
zram3 251:3 0 1.8G 0 disk [SWAP]
nvme0n1 259:0 0 465.8G 0 disk
├─nvme0n1p1 259:1 0 465.2G 0 part /
├─nvme0n1p2 259:2 0 64M 0 part
├─nvme0n1p3 259:3 0 64M 0 part
├─nvme0n1p4 259:4 0 448K 0 part
├─nvme0n1p5 259:5 0 448K 0 part
├─nvme0n1p6 259:6 0 80M 0 part
├─nvme0n1p7 259:7 0 512K 0 part
├─nvme0n1p8 259:8 0 300M 0 part
├─nvme0n1p9 259:9 0 64M 0 part
└─nvme0n1p10 259:10 0 18K 0 part
Notice there is no eMMC device listed. Running lsblk with -f option shows the following format types…
NAME FSTYPE LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
loop0 vfat L4T-README 1234-ABCD
zram0 [SWAP]
zram1 [SWAP]
zram2 [SWAP]
zram3 [SWAP]
nvme0n1
├─nvme0n1p1 ext4 7f4f3c24-7f8f-4544-8cc0-765edbd7de43 421.3G 4% /
├─nvme0n1p2
├─nvme0n1p3
├─nvme0n1p4
├─nvme0n1p5
├─nvme0n1p6
├─nvme0n1p7
├─nvme0n1p8
├─nvme0n1p9 vfat 7F76-CC3A
└─nvme0n1p10
Partitions 3 through 8 and 10 show now format type. Running fdisk -l shows the following for the NVMe drive:
Disk /dev/nvme0n1: 465.78 GiB, 500107862016 bytes, 976773168 sectors
Disk model: Samsung SSD 970 EVO Plus 500GB
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 5A500A9A-5CE3-4D39-BC01-05612C87A207
Device Start End Sectors Size Type
/dev/nvme0n1p1 1174352 976773128 975598777 465.2G Microsoft basic data
/dev/nvme0n1p2 40 131111 131072 64M Microsoft basic data
/dev/nvme0n1p3 131112 262183 131072 64M Microsoft basic data
/dev/nvme0n1p4 262184 263079 896 448K Microsoft basic data
/dev/nvme0n1p5 263080 263975 896 448K Microsoft basic data
/dev/nvme0n1p6 263976 427815 163840 80M Microsoft basic data
/dev/nvme0n1p7 427816 428839 1024 512K Microsoft basic data
/dev/nvme0n1p8 428840 1043239 614400 300M Microsoft basic data
/dev/nvme0n1p9 1043240 1174311 131072 64M EFI System
/dev/nvme0n1p10 1174312 1174347 36 18K Microsoft basic data
The other odd behavior is that after the flashing, it goes through a number of boot options before actually booting from NVMe. I was able to use efibootmgr to set the boot order to the NVMe drive but there are a number of other options listed and no eMMC option.
BootCurrent: 0001
Timeout: 5 seconds
BootOrder: 0001,0006,0005,0004,0003,0002,0000
Boot0000* UiApp
Boot0001* UEFI Samsung SSD 970 EVO Plus 500GB S58SNM0T701639V 1
Boot0002* UEFI PXEv4 (MAC:48B02D6783B0)
Boot0003* UEFI PXEv6 (MAC:48B02D6783B0)
Boot0004* UEFI HTTPv4 (MAC:48B02D6783B0)
Boot0005* UEFI HTTPv6 (MAC:48B02D6783B0)
Boot0006* UEFI Shell
The original boot order (after flashing) was set as follows:
BootOrder: 0005,0004,0003,0002,0001,0000,0006
So my questions…
(1) Are the 10 partitions on the NVMe drive supposed to be there?
(2) Why is there no eMMC device listed?
(3) Is the boot order options expected?
