I used a touchscreen with resolution 1280*800 on Xavier NX。Firstly ,it display ok,after server days,it display wrong.As the picture below,we can’t see the apply button,and can’t move to this position.But on another new Xavier NX,it display right again.
Appreciate your help !
Blockquote
[ 10444.744] (II) NVIDIA(0): Setting mode “HDMI-0: nvidia-auto-select @1280x800 +0+0 {ViewPortIn=1280x800, ViewPortOut=1280x800+0+0}”
[ 10444.776] () Option “fd” “34”
[ 10444.776] (II) event6 - Logitech USB Receiver: device removed
[ 10444.777] () Option “fd” “37”
[ 10444.778] () Option “fd” “38”
[ 10444.778] (II) event4 - ILITEK ILITEK-TP: device removed
[ 10444.779] () Option “fd” “39”
[ 10444.779] (II) event5 - gpio-keys: device removed
[ 10444.780] (**) Option “fd” “37”
[ 10444.780] (II) event7 - Logitech USB Receiver: device removed
[ 10445.021] (II) systemd-logind: got pause for 13:69
[ 10445.021] (II) systemd-logind: got pause for 13:71
[ 10445.021] (II) systemd-logind: got pause for 13:68
[ 10445.021] (II) systemd-logind: got pause for 13:70
[ 10448.439] (II) systemd-logind: got resume for 13:69
[ 10448.439] (–) NVIDIA(GPU-0): Amtrans AN-120W01 (DFP-0): connected
[ 10448.439] (–) NVIDIA(GPU-0): Amtrans AN-120W01 (DFP-0): External TMDS
[ 10448.489] (II) NVIDIA(0): Setting mode “HDMI-0: nvidia-auto-select @1280x800 +0+0 {ViewPortIn=1280x800, ViewPortOut=1280x800+0+0}”
[ 10448.623] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 10448.623] (II) NVIDIA(0): may not be running or the “AcpidSocketPath” X
[ 10448.623] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 10448.623] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 10448.623] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 10448.623] (II) NVIDIA(0): details, please see the “ConnectToAcpid” and
[ 10448.623] (II) NVIDIA(0): “AcpidSocketPath” X configuration options in Appendix B: X
[ 10448.623] (II) NVIDIA(0): Config Options in the README.
[ 10448.630] (II) event5 - gpio-keys: is tagged by udev as: Keyboard
[ 10448.630] (II) event5 - gpio-keys: device is a keyboard
[ 10448.632] (II) systemd-logind: got resume for 13:71
[ 10448.634] (II) event7 - Logitech USB Receiver: is tagged by udev as: Keyboard Mouse
[ 10448.634] (II) event7 - Logitech USB Receiver: device is a pointer
[ 10448.634] (II) event7 - Logitech USB Receiver: device is a keyboard
[ 10448.636] (II) systemd-logind: got resume for 13:68
[ 10448.637] (II) event4 - ILITEK ILITEK-TP: is tagged by udev as: Touchscreen
[ 10448.637] (II) event4 - ILITEK ILITEK-TP: device is a touch device
[ 10448.638] (II) systemd-logind: got resume for 13:70
[ 10448.640] (II) event6 - Logitech USB Receiver: is tagged by udev as: Keyboard
[ 10448.640] (II) event6 - Logitech USB Receiver: device is a keyboard
[ 10448.641] (–) NVIDIA(GPU-0): Amtrans AN-120W01 (DFP-0): connected
[ 10448.641] (–) NVIDIA(GPU-0): Amtrans AN-120W01 (DFP-0): External TMDS
[ 10448.642] (II) NVIDIA(0): Setting mode “HDMI-0: nvidia-auto-select @1280x800 +0+0 {ViewPortIn=1280x800, ViewPortOut=1280x800+0+0}”
[ 10448.969] (–) NVIDIA(GPU-0): Amtrans AN-120W01 (DFP-0): connected
[ 10448.969] (–) NVIDIA(GPU-0): Amtrans AN-120W01 (DFP-0): External TMDS
[ 10480.118] (–) NVIDIA(GPU-0): Amtrans AN-120W01 (DFP-0): connected
[ 10480.119] (–) NVIDIA(GPU-0): Amtrans AN-120W01 (DFP-0): External TMDS
YES,the problem is :the touchscreen display UI or other APP UI not correctly! We can’t move the apply button in the display setting UI ,or in another way to say , we can’t the see apply button. Before ,we use other display screen ,we can see it. Maybe the display driver or touch screen something wrong?
yes,I think the resolution is right,but I still cannot see the correct GUI on monitor.800600
xrandr -s 800600
Size index 800 is too large, there are only 8 sizes
kctii@kctii-desktop:~$ xrandr -s 720*560
Size index 720 is too large, there are only 8 sizes
Oh,I use “*” to set display resolution is wrong.Then i set 1280X800,it return to this resolution, the icon shows correctly.But I still can not move the display setting to see the APPLY button.
As the picture below shows, I can’t move this UI to show the bottom info.Other developed UI displays incorrectly! The touchscreem maximum resolution is 1280*800.Does “UI displaying wrong” relate to the touchscreen ? or Jetson Linux OS?
I use another AGX Xavier ,system display UI doesn’t show the APPLY button, or display not properly.
My app also display not correct,maybe relation to button size set.
On windows,it displays the UI or icons OK. Another picture,on x64 ubuntu PC,it contains two workspaces,the UI shows also correctly.I guess it maybe the Jetson system problem or touch screen driver problem.I will also check my UI setup.
I use a remote control software ,revise "the scale for menu and title bars ",other UI and fonts shows correctly!! But sometimes ,this value maybe become large again!
