That is why you can refer to other posts… they already shared the answer. Also, they even use the same GPIO as your case…
Related topics
Xavier NX SD card hot plug in/out | 14 | 1458 | October 18, 2021 | |
SD card on sdmmc3 is not working | 15 | 3952 | October 18, 2021 | |
Jetson_Xavier_NX SDMMC3(SD card) not found | 34 | 4003 | October 18, 2021 | |
How to enable Xavier NX SDIO to identify sd card slot? | 20 | 4194 | December 28, 2020 | |
Sdmmc microsd card doesn't work on JetPack 4.5.1 & 4.6 | 8 | 1764 | October 18, 2021 | |
Sdmmc sd card not worked on JetPack 4.6 | 8 | 1259 | October 18, 2021 | |
SDMMC3 can‘t work | 61 | 5938 | October 17, 2021 | |
SDMMC3 Error mmc1: CMD CRC or end bit error, int mask 0xa0000 | 41 | 2011 | August 31, 2022 | |
How to enable TF Card on Jetson Tx2 NX | 8 | 1001 | June 29, 2022 | |
Xavier NX external micro SD card is not working well | 7 | 797 | November 16, 2022 |
