H_Y
April 22, 2022, 2:35am
#1
I would like to make sure that we can use the both of external micro SD card and SSD at the same time with Xavier NX production module if we have the carrier board which has the micro SD slot and M.2 key M slot.
Is my understanding correct?
Thank you
Sure, as you can see in Xavier NX Design Guide, both are supported.
H_Y
April 22, 2022, 3:28am
#4
Hello, Trumany
Thank you for the reply to my question.
Can we utilize them at the same time , right? Not like either micro SD or SSD
Thank you
What do you mean “at the same time”? You can add a SD card and a SSD device in same one design.
H_Y
April 22, 2022, 4:26am
#6
While using the micro SD, can we also use the SSD together , at the same time?
Thank you
I don’t see any restrictions about this usecase. Why do you think it has chance to not work?
H_Y
April 22, 2022, 4:59am
#9
Thank you for the answer. I really appreciate it.
system
closed
May 18, 2022, 1:47am
#11
