hello everyone
When I use Xavier NX to migrate the system to nvme hard disks, after the disk pair is finished, modify the l4t-rootfs-uuid.txt and l4t-rootfs-uuid.txt_ext files under Linux_for_Tegra/bootloader, and then brush the boot option. After brushing can not start, the error uuid is incorrect, and then go back to look at the l4t-rootfs-uuid.txt_ext file found that the value inside it is changed, why?
Thanks for visiting the forums. Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
Hi yc13,
Are you using the devkit or custom board for Xavier NX?
How did you perform this?
Please share the full serial console log for further check.
