Hello!
My current setup is the following:
10x PowerEdge R730 2xE5-2650v3 @ 2.30Ghz with NVIDIA GRID K1
Its running XenServer 6.5 with Xendesktop 7.6 with all updates.
The Virtual Machine is configured the following:
4vcpu
K120Q
4gbram
I know the deepcompressioncodecv2 is encoding the stream on the CPU, but is it possible to use the GPU instead? Like the shadowplay and steam-in-home streaming is using? This would give a better experiance in my opinion.
Just for fun i installed steam and streamed half-life2 with 60fps @ 720p from the virutalmachine spec posted above. It was totally smooth experience.
Anyone from Nvidia have some trick up there sleve? Is it possible to disable the CPU encoding? I know this was possible in Xendesktop 5.6 with "DeepCompDisable" registry fix.
