I had no luck. Everything works the same. Please check CPU usage when VM (with K280Q) is booted and no app is running.
https://www.imageupload.co.uk/images/2015/10/07/CPU_usage.png
Bios is up to date.
Patches for Xenserver 6.2 installed
#lsmod | grep nvidia
nvidia 7547799 50
i2c_core 20294 1 nvidia
#dmesg | grep -E "NVRM"
[ 23.982887] NVRM: loading NVIDIA UNIX x86 Kernel Module 346.68 Sun Apr 26 20:17:20 PDT 2015
[ 37.166450] NVRM: Your system is not currently configured to drive a VGA console
[ 37.166452] NVRM: on the primary VGA device. The NVIDIA Linux graphics driver
[ 37.166453] NVRM: requires the use of a text-mode VGA console. Use of other console
[ 37.166454] NVRM: drivers including, but not limited to, vesafb, may result in
[ 37.166455] NVRM: corruption and stability problems, and is not supported.
#dmesg | grep -E “nvidia”
[ 23.537816] nvidia: module license ‘NVIDIA’ taints kernel.
[ 23.982172] nvidia 0000:04:00.0: enabling device (0000 -> 0003)
[ 23.982180] nvidia 0000:04:00.0: PCI INT A -> GSI 32 (level, low) -> IRQ 32
[ 23.982263] nvidia 0000:04:00.0: setting latency timer to 64
[ 23.982456] nvidia 0000:05:00.0: enabling device (0000 -> 0003)
[ 23.982461] nvidia 0000:05:00.0: PCI INT A -> GSI 32 (level, low) -> IRQ 32
[ 23.982477] nvidia 0000:05:00.0: setting latency timer to 64
[ 23.982702] nvidia 0000:06:00.0: PCI INT A -> GSI 40 (level, low) -> IRQ 40
[ 23.982714] nvidia 0000:06:00.0: setting latency timer to 64
[ 35.089524] nvidia 0000:04:00.0: get owner: 7ff0
[ 35.089599] nvidia 0000:04:00.0: irq 835 (291) for MSI/MSI-X
[ 35.910299] nvidia 0000:05:00.0: get owner: 7ff0
[ 35.910341] nvidia 0000:05:00.0: irq 834 (290) for MSI/MSI-X
[ 36.587080] nvidia 0000:06:00.0: get owner: 7ff0
[ 36.587107] nvidia 0000:06:00.0: irq 833 (289) for MSI/MSI-X
[ 66.857972] nvidia 0000:06:00.0: get owner: 7ff0
[ 69.746824] nvidia 0000:06:00.0: get owner: 7ff0
[ 69.746877] nvidia 0000:06:00.0: irq 833 (289) for MSI/MSI-X
[ 1977.700175] nvidia 0000:06:00.0: get owner: 7ff0
[ 1980.545937] nvidia 0000:06:00.0: get owner: 7ff0
[ 1980.545987] nvidia 0000:06:00.0: irq 833 (289) for MSI/MSI-X
[ 4408.935784] nvidia 0000:06:00.0: get owner: 7ff0
[ 4411.846006] nvidia 0000:06:00.0: get owner: 7ff0
[ 4411.846059] nvidia 0000:06:00.0: irq 833 (289) for MSI/MSI-X
[ 6489.225152] nvidia 0000:06:00.0: get owner: 7ff0
[ 6492.103800] nvidia 0000:06:00.0: get owner: 7ff0
#nvidia-smi
Wed Oct 7 21:23:56 2015
| NVIDIA-SMI 346.68 Driver Version: 346.68 |
| 0 GRID K2 On | 0000:04:00.0 Off | Off |
| N/A 35C P8 29W / 117W | 11MiB / 4095MiB | 0% Default |
| 1 GRID K2 On | 0000:05:00.0 Off | Off |
| N/A 32C P8 28W / 117W | 3787MiB / 4095MiB | 0% Default |
| 2 Quadro 2000 Off | 0000:06:00.0 Off | N/A |
| 30% 58C P8 N/A / N/A | 3MiB / 1023MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
