I am running Ubuntu 20.04.3 (HWE) LTS on a root server with a NVIDIA GeForce GT 710 and no attached monitor (headless). I have installed Ubuntu-desktop for some rendering stuff. The connection to the server is handled via teamviewer which is working pretty good with custom xorg.conf (see below). But I have two issues and I hope you can help me.
- Xorg.log shows a permission issue regarding the sideband socket (see below). According to several forum posts XServer is not running with root permissions by default. I found a recommendation to install “xserver-xorg-legacy” and modify /etc/X11/Xwrapper.config to require root permissions (see below). Unfortunately this didn’t worked and the error still exists. Any ideas?
- When running “nvidia-smi” there are no processes shown using the GPU. But /usr/lib/xorg/Xorg should using the GPU or I’m wrong?
XServer configuration to work headless
/usr/share/X11/xorg.conf.d/xorg.conf
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Samsung S22C350"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "NVIDIA GeForce GT 710"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "AllowEmptyInitialConfiguration" "True"
Option "UseDisplayDevice" "DFP-0"
Option "CustomEDID" "DFP-0:/usr/share/X11/edid.txt"
Option "ConnectedMonitor" "DFP-0"
SubSection "Display"
Depth 24
EndSubSection
EndSection
XServer legacy configuration
sudo apt install xserver-xorg-legacy
needs_root_rights=yes
allowed_users=anybody
XServer log file
~/.local/share/xorg/Xorg.1.log
[ 33.910] (WW) NVIDIA: Failed to bind sideband socket to
[ 33.910] (WW) NVIDIA: '/var/run/nvidia-xdriver-b203c470' Permission denied
nvidia-smi
| NVIDIA-SMI 470.86 Driver Version: 470.86 CUDA Version: 11.4 |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 N/A | N/A |
| 50% 42C P8 N/A / N/A | 160MiB / 981MiB | N/A Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
