Yo can anyone help me im on linux pop os and i have graphic card gtx 1650 and a dual monitor it doesnt work for my second monitor
so im new on linux so im very had no knowledge and u can someone help me to setup my second monitor
which is doesnt show up when i put xorg conf save file for my configuration on nvidia driver and i thought maybe that is the problem maybe it was xorg conf and i try to delete it and boot back up again it doesnt work so im confused rn what should i do i check a bit
here are the terminal.
command:
xranr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
DVI-D-0 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected primary 1878x1056+0+0 (normal left inverted right x axis y axis) 708mm x 398mm
   1920x1080     60.00*+  59.94    50.00    29.97    23.98
   1440x900      59.89
   1360x768      60.02
   1280x1024     60.02
   1280x720      59.94    50.00
   1024x768      60.00
   800x600       60.32
   720x576       50.00
   720x480       59.94
   640x480       59.94    59.93
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
so can someone help me troubleshoot i have no idea but yea
(sorry for bad english)
