• JETSON AGX ORIN
• DeepStream 7.0
• nvidia-jetpack - 6.0
• TensorRT - 8.6.2
• Question
I have an NVIDIA Jetson AGX Orin and I’m working on a YOLO v8 object detection project. Previously, I used DeepStream 6.2 and referred to the DeepStream YOLO repository, DeepStream_Python_Apps_Bindings_v1.1.6, and the Seed Studio tutorial. These resources worked fine with DeepStream 6.2. However, the Seed Studio tutorial only covers up to DeepStream 6.2.
The Seed Studio tutorial mentions a process to generate WTS and CFG files for use in the configuration file. Since the latest DeepStream YOLO repository doesn’t include files to generate WTS and CFG, I assume there’s no need to generate them and that I can use the ONNX model directly. I also clone the latest version of deepstream-python-apps
Running deepstream -c [config file] on Deepstream-Yolo works fine. However, when I use the PGIE config file with the DeepStream Python Apps test 1 (and the other example too), I get this following error:
Opening in BLOCKING MODE Setting min object dimensions as 16x16 instead of 1x1 to support VIC compute mode. WARNING: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps/deepstream-test1/model_b1_gpu0_fp32.engine open error 0:00:10.874194934 12205 0xaaaad196dca0 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2083> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps/deepstream-test1/model_b1_gpu0_fp32.engine failed 0:00:11.188088894 12205 0xaaaad196dca0 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2188> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps/deepstream-test1/model_b1_gpu0_fp32.engine failed, try rebuild 0:00:11.188145948 12205 0xaaaad196dca0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2109> [UID = 1]: Trying to create engine from model files WARNING: [TRT]: onnx2trt_utils.cpp:372: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32. Building the TensorRT Engine Building complete WARNING: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps/deepstream-test1/model_b1_gpu0_fp32.engine opened error 0:05:14.416695505 12205 0xaaaad196dca0 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2136> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps/deepstream-test1/model_b1_gpu0_fp32.engine WARNING: [TRT]: The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1. INFO: [Implicit Engine Info]: layers num: 2 0 INPUT kFLOAT images 3x640x640 1 OUTPUT kFLOAT output0 10x8400 0:05:14.757320821 12205 0xaaaad196dca0 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus: [UID 1]: Load new model:config_v8_ppe.txt sucessfully NvMMLiteOpen : Block : BlockType = 261 NvMMLiteBlockCreate : Block : BlockType = 261 Segmentation fault (core dumped)
Can someone provide me the right way to use yolo v8 with deepstream 7.0 and python binding?
here’s my config file :
[property] gpu-id=0 net-scale-factor=0.0039215697906911373 model-color-format=0 onnx-file=yolov8s.onnx model-engine-file=model_b1_gpu0_fp32.engine #int8-calib-file=calib.table labelfile-path=labels.txt batch-size=1 network-mode=0 num-detected-classes=80 interval=0 gie-unique-id=1 process-mode=1 network-type=0 cluster-mode=2 maintain-aspect-ratio=1 symmetric-padding=1 #workspace-size=2000 parse-bbox-func-name=NvDsInferParseYolo #parse-bbox-func-name=NvDsInferParseYoloCuda custom-lib-path=/home/agx/DeepStream-Yolo/nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.soengine-create-func-name=NvDsInferYoloCudaEngineGet [class-attrs-all] nms-iou-threshold=0.45 pre-cluster-threshold=0.25 topk=300
and i try to run the deepstream_test1.py with this config
here’s what gst_debug return :
Opening in BLOCKING MODE 0:00:00.224490201 8307 0xaaaae95f3010 WARN v4l2 gstv4l2object.c:4671:gst_v4l2_object_probe_caps:nvv4l2-decoder:src Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1 Setting min object dimensions as 16x16 instead of 1x1 to support VIC compute mode. 0:00:04.810548332 8307 0xaaaae95f3010 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2095> [UID = 1]: deserialized trt engine from :/home/agx/deepstream_python_apps/apps/deepstream-test1/model_b1_gpu0_fp32.engine WARNING: [TRT]: The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1. INFO: [Implicit Engine Info]: layers num: 2 0 INPUT kFLOAT images 3x640x640 1 OUTPUT kFLOAT output0 10x8400 0:00:05.089099451 8307 0xaaaae95f3010 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2198> [UID = 1]: Use deserialized engine model: /home/agx/deepstream_python_apps/apps/deepstream-test1/model_b1_gpu0_fp32.engine 0:00:05.099158085 8307 0xaaaae95f3010 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus: [UID 1]: Load new model:config_v8_ppe.txt sucessfully 0:00:05.099465246 8307 0xaaaae95f3010 WARN basesrc gstbasesrc.c:3688:gst_base_src_start_complete: pad not activated yet NvMMLiteOpen : Block : BlockType = 261 NvMMLiteBlockCreate : Block : BlockType = 261 0:00:05.202799491 8307 0xaaaae95f3860 WARN v4l2 gstv4l2object.c:4671:gst_v4l2_object_probe_caps:nvv4l2-decoder:src Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1 0:00:05.207116281 8307 0xaaaae95f3860 WARN v4l2videodec gstv4l2videodec.c:2311:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency 0:00:05.207582734 8307 0xaaaae95f3860 WARN v4l2bufferpool gstv4l2bufferpool.c:1116:gst_v4l2_buffer_pool_start:nvv4l2-decoder:pool:src Uncertain or not enough buffers, enabling copy threshold 0:00:05.221735796 8307 0xaaab304a8f60 WARN v4l2bufferpool gstv4l2bufferpool.c:1567:gst_v4l2_buffer_pool_dqbuf:nvv4l2-decoder:pool:src Driver should never set v4l2_buffer.field to ANY
