Yolo V8 Segmentation fault core dumped issue on Orin
Hi all,
I tried to create the basic Yolo V8 model on Jetson AGX Orin (both 32/64 GB variants) , while running below code on Jetson AGX Orin I am getting Segmentation Fault(core dumped)…
Installed all necessary packages on Jetson AGX Orin as per requirements mentioned & same file/setup I am able to run on my Host (windows) pc…
getting issues on Jetson AGX Orin board only,
please let me know if I miss any thing here,
Thanks in Advance…
Regards,
L V Giribabu.
Could you share the detailed steps for setting and reproducing the error?
So we can check it further?
  1. Flashed OS image - R35.4.1 (Jetpack 5.1.2) on Jetson AGX Orin (both 32/64 GB Variant’s)
  2. deep stream version - 6.3
  3. Downloaded Yolo V8 source code from git repo → GitHub - ultralytics/ultralytics: NEW - YOLOv8 🚀 in PyTorch > ONNX > OpenVINO > CoreML > TFLite
& followed steps as mentioned in that link & installed all necessary packages on Jetson AGX Orin as per
i) pip installed
ii) image
iii) Training the model on board
shared log file as below here for your reference…
same setup / file able to run / train the model on host(windows) pc,
plz let me know if u need any info for the same…
Thanks,
L V Giribabu
Thanks for the details.
Will get back to you later.
Ok, Sure.
Thanks & best regards,
L V Giribabu.
Can you please give any update for the same?
Thanks in Advance.
Thanks,
L V Giribabu.
Can u please share any inputs for the same?
Thanks,
L V Giribabu.
Thanks for your patience.
$ pip3 install ultralytics
Above command will download a CPU PyTorch package and cause the segmentation fault error.
Please reinstall PyTorch with our GPU prebuilt to fix this issue…
$ sudo apt-get -y install autoconf bc build-essential g++-8 gcc-8 clang-8 lld-8 gettext-base gfortran-8 iputils-ping libbz2-dev libc++-dev libcgal-dev libffi-dev libfreetype6-dev libhdf5-dev libjpeg-dev liblzma-dev libncurses5-dev libncursesw5-dev libpng-dev libreadline-dev libssl-dev libsqlite3-dev libxml2-dev libxslt-dev locales moreutils openssl python-openssl rsync scons python3-pip libopenblas-dev;
$ python3 -m pip install --upgrade pip; python3 -m pip install aiohttp numpy=='1.19.4' scipy=='1.5.3' export "LD_LIBRARY_PATH=/usr/lib/llvm-8/lib:$LD_LIBRARY_PATH"; python3 -m pip install --upgrade protobuf; python3 -m pip install --no-cache https://developer.download.nvidia.cn/compute/redist/jp/v511/pytorch/torch-2.0.0+nv23.05-cp38-cp38-linux_aarch64.whl
Then try the YOLOv8 command again.
Sure, will check it & let u know…
Thanks for ur quick reply…
Regards,
L V giribabu
Yes, now I am able to run & create the customized model,
Thank you for ur kind support.
Regards,
L V Giribabu.
Good to know this.
Thanks for the update.
