The jetson-utils library worked great for feeding live CAM0 video frames. See above thread. Also have a working python program to run Yolo11 object detection from an mp4 video file.
Then I tried running object detection with live camera videostream. I created a new program
to feed jetson-utils video frames to the Yolo model “function”. See code below:
import cv2
import numpy as np
from ultralytics import YOLO
import sys
from jetson_utils import videoSource, videoOutput, Log
# Load YOLO TRT model
model = YOLO("/home/jet/robotics/yolo/example01/yolo11n.engine")
# Jetson_Utils initialize
input = videoSource()
output = videoOutput()
# process frames until EOS or the user exits
while True:
# capture the next image
frame = input.Capture()
if frame is None: # timeout
continue
# render the image
#output.Render(frame)
# exit on input/output EOS
if not input.IsStreaming() or not output.IsStreaming():
break
# Perform Yolo object detection on the frame
results = model(frame)
for resx in results:
boxes = resx.boxes # Boxes object for bounding box outputs
masks = resx.masks # Masks object for segmentation masks outputs
keypoints = resx.keypoints # Keypoints object for pose outputs
probs = resx.probs # Probs object for classification outputs
obb = resx.obb # Oriented boxes object for OBB outputs
print(boxes)
However, the program failed - see results below. The Yolo “model” function expects a frame input, but does not recognize the “frame” result coming from the jetson_utils “input.Capture()” function. How can I reconcile this?
jet@sky:~/robotics/yolo/example01$ python3 detect_v04_camera.py
WARNING ⚠️ Unable to automatically guess model task, assuming 'task=detect'. Explicitly define task for your model, i.e. 'task=detect', 'segment', 'classify','pose' or 'obb'.
[gstreamer] initialized gstreamer, version 1.20.3.0
[gstreamer] gstCamera -- attempting to create device csi://0
[gstreamer] gstCamera pipeline string:
[gstreamer] nvarguscamerasrc sensor-id=0 ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=30/1, format=(string)NV12 ! nvvidconv flip-method=2 ! video/x-raw ! appsink name=mysink
[gstreamer] gstCamera successfully created device csi://0
[video] created gstCamera from csi://0
gstCamera video options:
-- URI: csi://0
- protocol: csi
-- deviceType: csi
-- ioType: input
-- width: 1280
-- height: 720
-- frameRate: 30
-- numBuffers: 4
-- zeroCopy: true
-- flipMethod: rotate-180
[OpenGL] glDisplay -- X screen 0 resolution: 3840x2160
[OpenGL] glDisplay -- X window resolution: 3840x2160
[OpenGL] glDisplay -- display device initialized (3840x2160)
[video] created glDisplay from display://0
glDisplay video options:
-- URI: display://0
- protocol: display
-- deviceType: display
-- ioType: output
-- width: 3840
-- height: 2160
-- frameRate: 0
-- numBuffers: 4
-- zeroCopy: true
[gstreamer] opening gstCamera for streaming, transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter1
[gstreamer] gstreamer changed state from NULL to READY ==> nvvconv0
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter0
[gstreamer] gstreamer changed state from NULL to READY ==> nvarguscamerasrc0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter1
[gstreamer] gstreamer changed state from READY to PAUSED ==> nvvconv0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter0
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> nvarguscamerasrc0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer message new-clock ==> pipeline0
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> nvvconv0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> nvarguscamerasrc0
[gstreamer] gstreamer message stream-start ==> pipeline0
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3280 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3280 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 4
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 59.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
[gstreamer] gstCamera -- onPreroll
[gstreamer] gstBufferManager -- map buffer size was less than max size (1382400 vs 1382407)
[gstreamer] gstBufferManager recieve caps: video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)30/1, format=(string)NV12
[gstreamer] gstBufferManager -- recieved first frame, codec=raw format=nv12 width=1280 height=720 size=1382407
[cuda] allocated 4 ring buffers (1382407 bytes each, 5529628 bytes total)
[cuda] allocated 4 ring buffers (8 bytes each, 32 bytes total)
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
[gstreamer] gstreamer message async-done ==> pipeline0
[gstreamer] gstreamer message latency ==> mysink
[gstreamer] gstreamer message warning ==> mysink
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> mysink
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> pipeline0
[cuda] allocated 4 ring buffers (2764800 bytes each, 11059200 bytes total)
Loading /home/jet/robotics/yolo/example01/yolo11n.engine for TensorRT inference...
[07/10/2025-00:43:30] [TRT] [I] Loaded engine size: 5 MiB
[07/10/2025-00:43:30] [TRT] [W] Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
[07/10/2025-00:43:31] [TRT] [I] [MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +0, GPU +12, now: CPU 0, GPU 14 (MiB)
File "/home/jet/robotics/yolo/example01/detect_v04_camera.py", line 40, in <module>
File "/home/jet/.local/lib/python3.10/site-packages/ultralytics/engine/model.py", line 181, in __call__
return self.predict(source, stream, **kwargs)
File "/home/jet/.local/lib/python3.10/site-packages/ultralytics/engine/model.py", line 559, in predict
return self.predictor.predict_cli(source=source) if is_cli else self.predictor(source=source, stream=stream)
File "/home/jet/.local/lib/python3.10/site-packages/ultralytics/engine/predictor.py", line 175, in __call__
return list(self.stream_inference(source, model, *args, **kwargs)) # merge list of Result into one
File "/home/jet/.local/lib/python3.10/site-packages/torch/utils/_contextlib.py", line 36, in generator_context
response = gen.send(None)
File "/home/jet/.local/lib/python3.10/site-packages/ultralytics/engine/predictor.py", line 233, in stream_inference
self.setup_source(source if source is not None else self.args.source)
File "/home/jet/.local/lib/python3.10/site-packages/ultralytics/engine/predictor.py", line 205, in setup_source
self.dataset = load_inference_source(
File "/home/jet/.local/lib/python3.10/site-packages/ultralytics/data/build.py", line 199, in load_inference_source
source, stream, screenshot, from_img, in_memory, tensor = check_source(source)
File "/home/jet/.local/lib/python3.10/site-packages/ultralytics/data/build.py", line 181, in check_source
raise TypeError("Unsupported image type. For supported types see https://docs.ultralytics.com/modes/predict")
TypeError: Unsupported image type. For supported types see https://docs.ultralytics.com/modes/predict
[gstreamer] gstCamera -- stopping pipeline, transitioning to GST_STATE_NULL
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
[gstreamer] gstCamera -- pipeline stopped```
