HIVE
July 11, 2020, 8:25am
1
Dear folks,
I want to run ds python apps with yolov3 detector (not familier with C/C++). I found the “deepstream_test1_rtsp_out.py” in python bindings just fit my purpose. The configuration file for its pgie looks like this:
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-file=../../../../samples/models/Primary_Detector/resnet10.caffemodel
model-engine-file=../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
proto-file=../../../../samples/models/Primary_Detector/resnet10.prototxt
labelfile-path=../../../../samples/models/Primary_Detector/labels.txt
int8-calib-file=../../../../samples/models/Primary_Detector/cal_trt.bin
batch-size=1
network-mode=1
num-detected-classes=4
interval=0
gie-unique-id=1
output-blob-names=conv2d_bbox;conv2d_cov/Sigmoid
[class-attrs-all]
threshold=0.2
eps=0.2
group-threshold=1
The C deepstream-app has an example config called “config_infer_primary_yoloV3.txt”, looking like this:
[property]
gpu-id=0
#0=RGB, 1=BGR
model-color-format=0
custom-network-config=yolov3.cfg
model-file=yolov3.weights
#model-engine-file=yolov3_b1_gpu0_int8.engine
labelfile-path=labels.txt
int8-calib-file=yolov3-calibration.table.trt7.0
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
num-detected-classes=80
gie-unique-id=1
network-type=0
is-classifier=0
## 0=Group Rectangles, 1=DBSCAN, 2=NMS, 3= DBSCAN+NMS Hybrid, 4 = None(No clustering)
cluster-mode=2
maintain-aspect-ratio=1
parse-bbox-func-name=NvDsInferParseCustomYoloV3
custom-lib-path=nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so
engine-create-func-name=NvDsInferYoloCudaEngineGet
#scaling-filter=0
#scaling-compute-hw=0
[class-attrs-all]
nms-iou-threshold=0.3
threshold=0.7
If I want to use python bindings to run the yolov3 detector, what should I do to deal with the configuration file?
**• Hardware Platform (Jetson / GPU)**GPU titanV
• DeepStream Version 5.0
• TensorRT Version 7.0.0.11
• NVIDIA GPU Driver Version (valid for GPU only) 440.33
Amycao
July 13, 2020, 10:05am
3
You could run with the yolo config using python sample, but need to change the file location accordingly.
model-file
labelfile-path
int8-calib-file
custom-lib-path
HIVE
July 14, 2020, 7:24am
4
Ok. Got it. It is working now! The yolov3 runs very well. Thanks for the instruction.
A follow-up question is that if I want to use 8bit precision, how can I do the calibiration and obtain the calibration table?
I see there is a calibration file :“yolov3-calibration.table.trt7.0”, but it is for coco dataset. I have a custom dataset, is there any way to do the calibration and get this table?
Amycao
July 15, 2020, 3:29am
5
HIVE
July 15, 2020, 11:20am
6
OK. Thanks. I will see to it.
When I ran my customed yolov3 with coco dataset, it always pop up an error. Though it does stop running, I still want to know how this happens:
Frame Number=1318 Number of Objects=6 Vehicle_count=2 Person_count=4
File "deepstream_test1_rtsp_out.py", line 84, in osd_sink_pad_buffer_probe
obj_counter[obj_meta.class_id] += 1
KeyError: 7
Frame Number=1320 Number of Objects=5 Vehicle_count=2 Person_count=3
KeyError: 7
KeyError: 7
I does not notice any problem regarding the code. Any idea?
frame_number=frame_meta.frame_num
num_rects = frame_meta.num_obj_meta
l_obj=frame_meta.obj_meta_list
while l_obj is not None:
try:
# Casting l_obj.data to pyds.NvDsObjectMeta
obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
except StopIteration:
break
try:
l_obj=l_obj.next
break
Amycao
July 16, 2020, 3:21am
8
code clip seems correct, how many classes your customized model have?
HIVE
July 16, 2020, 8:36am
9
I think it is the classes num causes this problem. You are right! I have more than 10 classes, but the object counter only has 4:
#Intiallizing object counter with 0.
obj_counter = {
PGIE_CLASS_ID_VEHICLE:0,
PGIE_CLASS_ID_PERSON:0,
PGIE_CLASS_ID_BICYCLE:0,
PGIE_CLASS_ID_ROADSIGN:0
num_rects=0
I need to add all classes here, right?
Amycao
July 17, 2020, 2:40am
10
HIVE:
Can you change num-detected-classes=4 in config to class numbers of your model?
HIVE
July 17, 2020, 10:57am
11
Yeap, I see. This works fine.
The problem is I have more than 4 classes to detect, say, 16 classes. So If I change it like this, it may not display the detections of more than 4 classes.
HIVE
July 20, 2020, 3:33am
13
I have figured it out.
This issue could be closed, and thanks for your patience @Amycao
Amycao
July 20, 2020, 4:06am
14
Thanks for let us knowing.
