Yolov8-OBB model in DeepStream
• Hardware Platform (Jetson / GPU) NVIDIA GeForce RTX 3090
• DeepStream Version 7.0
• TensorRT Version 8.6.1.6
• NVIDIA GPU Driver Version (valid for GPU only) 535.171.04
• Issue Type( questions, new requirements, bugs) Question
I have already used DeepStream SDK with the Yolov8 model and it works fine. Last week I noticed about the new Yolov8-OBB model that apart from giving the bounding box it also provides the orientation of it. For my project it’s ideal and I tried to apply it to DeepStream, however I am not able to obtain that orientation parameter. I have followed the same method that I used to implement the Yolov8 version (DeepStream-YOLO) .
Is it possible to implement this new model in DeepStream?
You need to implement the postprocess process according to your own model. You can try to modify the nvdsinfer_custom_impl_Yolo code to implement your needs.
Thanks! I suppose that I have to change the script that I attach, the nvdsparsebbox_Yolo.cpp (nvdsparsebbox_Yolo.cpp.txt (7.0 KB)).
In the config file, the parse-bbox-func-name uses the function that is in this script, NvDsInferParseYolo. However, I see that this function uses the NvDsInferParseObjectInfo structure. Can I modify this structure and add another parameter like b.rotation or it is fixed?
It’s fixed in the code currently. But since it’s open source, you can try to add that in the sources\includes\nvdsinfer.h file.
sources\includes\nvdsinfer.h file or sources\includes\nvdsinfer_custom_impl.h? This last one is the one included in the nvdsparsebbox_Yolo.cpp
 * Holds information about one parsed object from a detector's output.
typedef struct
  /** Holds the ID of the class to which the object belongs. */
  unsigned int classId;
  /** Holds the horizontal offset of the bounding box shape for the object. */
  float left;
  /** Holds the vertical offset of the object's bounding box. */
  float top;
  /** Holds the width of the object's bounding box. */
  float width;
  /** Holds the height of the object's bounding box. */
  float height;
  /** Holds the object detection confidence level; must in the range
   [0.0,1.0]. */
  float detectionConfidence;
} NvDsInferObjectDetectionInfo;
I see, thank you! About the model, I would be very grateful if you could help me to integrate it, as I don’t have so much knowledge in these matters … in what format do you want to share it?
It’s mostly up to yourself to integrate it according to your own needs. Any problems encountered during the integration can be discussed on this topic.
It is best to share it in ONNX format.
Okay, I will try it mysefl.
In case you can help me, I attach the model and the labels.
best.onnx.txt (43.6 MB)
labels.txt (6 Bytes)
Thanks for all!
We suggest you run the pipeline with the OBB model successfully first and discuss it in detail later when you encounter the specific problems.
