Hello!
I am using Jetson TX2 with the carrier board auvedia J140.
The custom firmware from auvedia, JetPack 4.3, is flashed on the jetson, since it provides the USB3.0. (see the description at the end)
I would like to use ZED mini with Jetson. The ZED SDK for Jetson is installed.
But I have trouble to connect the camera. I tried both usb ports, rotated the usb mini port cable (since it seems not to be reversible, see https://support.stereolabs.com/hc/en-us/articles/360010101213-What-do-I-do-if-my-ZED-ZED-Mini-is-not-working-). I also connected the ZED mini to my notebook, to be sure that cable and camera itself is ok. On notebook it works without any issue.
Here is some output:
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 011: ID 046d:c050 Logitech, Inc. RX 250 Optical Mouse
Bus 001 Device 016: ID 046a:0023 Cherry GmbH CyMotion Master Linux Keyboard G230
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 018: ID 2b03:f681
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
How you can see the 2b03:f681 is detected, but 2b03:f680, video device, is missing.
lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/3p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 480M
|__ Port 2: Dev 18, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 3: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 3: Dev 16, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 3: Dev 16, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 4: Dev 11, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
[ 102.094011] usb 1-2: new full-speed USB device number 17 using tegra-xusb
[ 102.117433] usb 1-2: New USB device found, idVendor=2b03, idProduct=f681
[ 102.117458] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 102.117475] usb 1-2: Product: ZED-M Hid Device
[ 102.117489] usb 1-2: Manufacturer: STEREOLABS
[ 102.117502] usb 1-2: SerialNumber: 10025959
[ 102.121699] hid-generic 0003:2B03:F681.0005: hidraw0: USB HID v1.11 Device [STEREOLABS ZED-M Hid Device] on usb-3530000.xhci-2/input0
[ 128.607506] nvgpu: 17000000.gp10b railgate_enable_store:297 [INFO] railgate is disabled.
[ 248.867815] nvgpu: 17000000.gp10b railgate_enable_store:297 [INFO] railgate is disabled.
[ 289.885050] usb 1-2: USB disconnect, device number 17
[ 369.099149] nvgpu: 17000000.gp10b railgate_enable_store:297 [INFO] railgate is disabled.
[ 489.379956] nvgpu: 17000000.gp10b railgate_enable_store:297 [INFO] railgate is disabled.
[ 565.357097] usb 1-2: new full-speed USB device number 18 using tegra-xusb
[ 565.379695] usb 1-2: New USB device found, idVendor=2b03, idProduct=f681
[ 565.379701] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 565.379704] usb 1-2: Product: ZED-M Hid Device
[ 565.379706] usb 1-2: Manufacturer: STEREOLABS
[ 565.379709] usb 1-2: SerialNumber: 10025959
[ 565.381452] hid-generic 0003:2B03:F681.0006: hidraw0: USB HID v1.11 Device [STEREOLABS ZED-M Hid Device] on usb-3530000.xhci-2/input0
[ 609.552727] nvgpu: 17000000.gp10b railgate_enable_store:297 [INFO] railgate is disabled.
[ 729.846467] nvgpu: 17000000.gp10b railgate_enable_store:297 [INFO] railgate is disabled.
[ 850.088829] nvgpu: 17000000.gp10b railgate_enable_store:297 [INFO] railgate is disabled.
[ 970.338667] nvgpu: 17000000.gp10b railgate_enable_store:297 [INFO] railgate is disabled.
[ 1090.585221] nvgpu: 17000000.gp10b railgate_enable_store:297 [INFO] railgate is disabled.
[ 1096.782836] eqos 2490000.ether_qos eth0: Link is Down
[ 1100.957735] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 1210.838544] nvgpu: 17000000.gp10b railgate_enable_store:297 [INFO] railgate is disabled.
[ 1331.122226] nvgpu: 17000000.gp10b railgate_enable_store:297 [INFO] railgate is disabled.
[ 1451.328842] nvgpu: 17000000.gp10b railgate_enable_store:297 [INFO] railgate is disabled.
[ 1512.190690] usb 1-2: USB disconnect, device number 18
[ 1526.431450] usb 1-2: new full-speed USB device number 19 using tegra-xusb
[ 1526.454184] usb 1-2: New USB device found, idVendor=2b03, idProduct=f681
[ 1526.454189] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1526.454192] usb 1-2: Product: ZED-M Hid Device
[ 1526.454195] usb 1-2: Manufacturer: STEREOLABS
[ 1526.454197] usb 1-2: SerialNumber: 10025959
[ 1526.455914] hid-generic 0003:2B03:F681.0007: hidraw0: USB HID v1.11 Device [STEREOLABS ZED-M Hid Device] on usb-3530000.xhci-2/input0
[ 1566.316978] usb 1-2: USB disconnect, device number 19
[ 1569.555084] usb 1-2: new full-speed USB device number 20 using tegra-xusb
[ 1569.577862] usb 1-2: New USB device found, idVendor=2b03, idProduct=f681
[ 1569.577866] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1569.577869] usb 1-2: Product: ZED-M Hid Device
[ 1569.577872] usb 1-2: Manufacturer: STEREOLABS
[ 1569.577874] usb 1-2: SerialNumber: 10025959
[ 1569.579696] hid-generic 0003:2B03:F681.0008: hidraw0: USB HID v1.11 Device [STEREOLABS ZED-M Hid Device] on usb-3530000.xhci-2/input0
[ 1571.568664] nvgpu: 17000000.gp10b railgate_enable_store:297 [INFO] railgate is disabled.
[ 1691.818149] nvgpu: 17000000.gp10b railgate_enable_store:297 [INFO] railgate is disabled.
Thank you a lot in advance!
Here is the data of the firmware:
Source: Firmware – Auvidea
Feb 2020 J140
https://auvidea.eu/download/firmware/J140/J140_4_3.tar.bz2
supports: Jetson TX2 only
– JetPack 4.3 (L4T 32.3.1)
– 1x USB 3.0
– IMU MPU9250 (spidev1.0)
– 2x GbE (native and i210)
– 1x M.2 NVME PCIe x4
– port mapping: config 1
