Zorah download sample link is broken
same issue with me, i cant seem to find any link to it
Same here.
Yes, I have the same problem, can’t download!!! Please nvidia fix it.
Another successful bait & switch by Nvidia just like RTX Racer.
Looks like no news on this. The Zorah Sample is not being made public?
Thank you @TomNVIDIA ,
Please, do you know if the sample scenes can be migrated and used in any Unreal commercial project --using the standard Epic’s engine branch-- like most of the Unreal samples projects (from Epic)? Or this would apply different license terms, from your side?
Thank you!
The Zorah sample is released under MIT OSS license, which is quite permissive, so you should be able to use it with any Unreal brach. From a technology perspective, they are meant to be used together with the Experimental branch of NvRTX that has Mega Geometry and ReSTIR-GI with PT - so your mileage may vary as to how much benefit there is without those technologie present.
It seems that the download in the RTX kit is also broken. The downloaded file is only 16 MB in size.
