Is there anything preventing an x264-encoded bitstream from being decoded? I’m generating an x264-encoded bitstream via ffmpeg:
$ ffmpeg -f lavfi -i testsrc=duration=5 -c:v libx264 -f h264 test.h264
Then decoding it with 00_video_decode:
$ ./video_decode H264 --disable-rendering -o ~/test.yuv ~/test.h264
Set governor to performance before enabling profiler
Creating decoder in blocking mode
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Setting frame input mode to 1
Input file read complete
Starting decoder capture loop thread
[NvMediaParserParse:357] Video parser parse failed: 0[NvMediaParserParse:357] Video parser parse failed: 0Got EoS at output plane
[ERROR] (NvV4l2Element.cpp:115) <dec0> Error while DQing event: Invalid argument
Error in dequeueing decoder event
Exiting decoder capture loop thread
App run failed
Not sure why it’s failing to parse. The sample, of course, works if I use NvVideoEncoder to generate the video. Similarly,
$ gst-launch-1.0 filesrc location=test.h264 ! h264parse ! avdec_h264 ! fakesink
has no issues playing the file.
