Hi
I had use jetson sdk manager from host pc to flash jetpack 4.2.1 with deepstream sdk on Jetson Xavier,
but the sample_1080p_h264.mp4 playback was lag seriously by clicking the mp4 file in the files manager
, the sample_720p.mp4 playback was normal.
After that , I had downloaded the 1080p/720p video from
https://www.appsloveworld.com/2018/10/sample-mp4-video.html , and find the same results.
Could someone verify this problem?
BRs,
Albert
cellius
September 2, 2019, 3:28pm
3
Hi
“If you double click the video file, the video playback is not run with hardware acceleration. Please try gatreamer or tegra_multimedia_api.”
I don’t understand fully yet. In case Jeson Nano, Jeson Tx2 , it has no this problem.(Jetpack 4.2.2 has same problem)
I want to know the cause.
Best Regard
DaneLLL
September 3, 2019, 1:32am
4
By clicking a video file in file manager, the video playback uses ffmpeg and is software decoding. On Xavier, you can run ‘sudo nvpmovel -m 0’ and ‘sudo jetson_clocks’ to get max CPU clocks and benefit decoding performance.
cellius
September 3, 2019, 2:11am
5
HI
I’ve already tested what you suggest, but the problem is pretty much the same: a little faster.Xavier is very hot!!
Jeson Nano and TX2 do not have this problem.
Please check if the hardware decoder part is ported properly.
DaneLLL
September 3, 2019, 2:23am
6
