1080ti core clock stays at idle speed with p0 and SW Cap active only with DisplayPort
Hi Nvidia Forum,
My GF built herself a new PC and also got a new Monitor (M27Q). We tested the new Monitor on the old system and it went fine, Gsync worked, WQHD+170hz was nice. After 2-3 new boots the games startet to stutter and there was a heavy mouse lag, i checked it and saw the GPU Core clock was at idle speed (~250mhz) the memory clock was fine.
After that i checked the following:
New DP Cables (Old one i had, new one that came with monitor, the one of my main rig)
Different DP Port
Disable Gsync
New Driver
Apply OC with MSI Afterburner + increase Powerlimit (that only adjusted the frequency + limit over the idle limits)
What helped on a short term was applying the afterburner OC Scanner and cancel it. After a reboot it stuck again and oc scanner didnt helped.
We then built the new system and hoped for a conflict in the old one. So everything new except the graphics card. First it worked, then the behaviour occured again.
What then helped was a HDMI Cable, we plugged it in, set it to maximum 144 hz and it worked. Sadly no gsync and that itches me a bit, because we payed for it.
So today i tried a few things again,
Plugged the Monitor on my main system with a 4080 super, worked everything fine, even after reboots.
I plugged my monitor (Dell 34 Inch awf) on the 1080ti and the core clock was idle again.
Reinstalled GPU Driver with DDU → no success
Disabled Onboard CPU Graphics → no success
Deinstalled Afterburner → no success
What then helped was setting the frequency to 60hz, no matter if Gsync is on or off. I cant explain that behaviour of the GPU, can anyone helped me out?
New PC Specs:
Windows 11 newest Release
7600X3D
MSI B650 Tomahawk WIFI
2x16 GB Corsair Ram with EXPO 1
Asus 1080ti Strix OC Editon
Bequiet Straight Power 750W
MSI Drivers are all there, also CPU Chipset, Nvidia Driver is the newest and i also tried one of 2024.
I can somewhat fix it by setting the monitor to 60hz, then the powerstate wents from p0 to p8 and i get proper core clocks.
I now installed cuda to check some information but i cant change anything.
Timestamp : Mon Mar 3 12:20:13 2025
Driver Version : 560.94
CUDA Version : 12.6
Attached GPUs : 1
GPU 00000000:01:00.0
Performance State : P0
Clocks Event Reasons
Idle : Not Active
Applications Clocks Setting : Not Active
SW Power Cap : Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
Sparse Operation Mode : N/A
==============NVSMI LOG==============
Timestamp : Mon Mar 3 12:21:46 2025
CUDA Version : 12.6
Attached GPUs : 1
Product Name : NVIDIA GeForce GTX 1080 Ti
Product Brand : GeForce
Product Architecture : Pascal
Display Mode : Enabled
Display Active : Enabled
Persistence Mode : N/A
Addressing Mode : N/A
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : WDDM
Pending : WDDM
Serial Number : N/A
GPU UUID : GPU-b8a6fe1c-49cc-8075-7b1f-0013eca41675
Minor Number : N/A
VBIOS Version : 86.02.39.00.54
MultiGPU Board : No
Board ID : 0x100
Board Part Number : N/A
GPU Part Number : 1B06-350-A1
FRU Part Number : N/A
Module ID : 1
Inforom Version
Image Version : G001.0000.01.04
OEM Object : 1.1
ECC Object : N/A
Power Management Object : N/A
Inforom BBX Object Flush
Latest Timestamp : N/A
Latest Duration : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU C2C Mode : N/A
GPU Virtualization Mode
Virtualization Mode : None
Host VGPU Mode : N/A
vGPU Heterogeneous Mode : N/A
GPU Reset Status
Reset Required : No
Drain and Reset Recommended : N/A
GSP Firmware Version : N/A
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Device Id : 0x1B0610DE
Bus Id : 00000000:01:00.0
Sub System Id : 0x85EB1043
GPU Link Info
PCIe Generation
Max : 3
Current : 3
Device Current : 3
Device Max : 3
Host Max : 5
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 2 KB/s
Rx Throughput : 26 KB/s
Atomic Caps Outbound : N/A
Atomic Caps Inbound : N/A
Fan Speed : 0 %
Idle : Not Active
FB Memory Usage
Total : 11264 MiB
Reserved : 158 MiB
Used : 1141 MiB
Free : 9966 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 229 MiB
Free : 27 MiB
Conf Compute Protected Memory Usage
Total : N/A
Used : N/A
Free : N/A
Compute Mode : Default
Utilization
Gpu : 3 %
Memory : 1 %
Encoder : 0 %
Decoder : 0 %
JPEG : N/A
OFA : N/A
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
ECC Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Texture Memory : N/A
Texture Shared : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows : N/A
Temperature
GPU Current Temp : 54 C
GPU T.Limit Temp : N/A
GPU Shutdown Temp : 96 C
GPU Slowdown Temp : 93 C
GPU Max Operating Temp : N/A
GPU Target Temperature : 84 C
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
GPU Power Readings
Power Draw : 65.37 W
Current Power Limit : 250.00 W
Requested Power Limit : 250.00 W
Default Power Limit : 250.00 W
Min Power Limit : 125.00 W
Max Power Limit : 300.00 W
GPU Memory Power Readings
Power Draw : N/A
Module Power Readings
Power Draw : N/A
Current Power Limit : N/A
Requested Power Limit : N/A
Default Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Clocks
Graphics : 253 MHz
SM : 253 MHz
Memory : 5622 MHz
Video : 746 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Deferred Clocks
Memory : N/A
Max Clocks
Graphics : 1923 MHz
SM : 1923 MHz
Memory : 5505 MHz
Video : 1620 MHz
Welcome to the NVIDIA Developer forums. This community serves the developer ecosystem.
For consumer issues, please visit the GeForce forums.
Best regards
This is a bug in Nvidia drivers. We have a thread here with people complaining about the same issue: GPU is stuck to maximun power state at idle when using multiple monitors
