Hey all, I am attempting to use surfaces. It compiles fine but when I run it, it says “error in ptx line ## near .surf”.
If anyone has any example code that uses surfaces, it would be EXTREMELY helpful. The programming guide uses surface<void, 2> but the API will not let me bind the surfaces unless they are of a type! The programming guide has utterly failed me this time.
Thank you in advance!
Clamport
We are working on a surfaces SDK sample and will post it here when it’s ready. Thanks!
