[ 0.310997] pnp 00:03: disabling [io 0x002e-0x002f] because it overlaps 0000:02:00.0 BAR 5 [io 0x0000-0x007f]
[ 0.310998] pnp 00:03: disabling [io 0x004e-0x004f] because it overlaps 0000:02:00.0 BAR 5 [io 0x0000-0x007f]
[ 0.310999] pnp 00:03: disabling [io 0x0061] because it overlaps 0000:02:00.0 BAR 5 [io 0x0000-0x007f]
[ 0.311000] pnp 00:03: disabling [io 0x0063] because it overlaps 0000:02:00.0 BAR 5 [io 0x0000-0x007f]
[ 0.311000] pnp 00:03: disabling [io 0x0065] because it overlaps 0000:02:00.0 BAR 5 [io 0x0000-0x007f]
[ 0.311001] pnp 00:03: disabling [io 0x0067] because it overlaps 0000:02:00.0 BAR 5 [io 0x0000-0x007f]
[ 0.311002] pnp 00:03: disabling [io 0x0070] because it overlaps 0000:02:00.0 BAR 5 [io 0x0000-0x007f]
[ 0.318899] pci 0000:02:00.0: BAR 1: assigned [mem 0x4010000000-0x401fffffff 64bit pref]
[ 0.318911] pci 0000:02:00.0: BAR 3: assigned [mem 0x4008000000-0x4009ffffff 64bit pref]
[ 0.318918] pci 0000:02:00.0: BAR 0: no space for [mem size 0x01000000]
[ 0.318919] pci 0000:02:00.0: BAR 0: failed to assign [mem size 0x01000000]
[ 0.318920] pci 0000:02:00.0: BAR 6: assigned [mem 0xc4280000-0xc42fffff pref]
[ 0.318921] pci 0000:02:00.0: BAR 5: assigned [io 0x5000-0x507f]
[ 0.318923] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.318925] pci 0000:00:1c.0: bridge window [io 0x5000-0x5fff]
[ 0.318927] pci 0000:00:1c.0: bridge window [mem 0xc4200000-0xc42fffff]
[ 0.318929] pci 0000:00:1c.0: bridge window [mem 0x4008000000-0x401fffffff 64bit pref]
[ 0.318932] pci 0000:00:1d.0: PCI bridge to [bus 03]
[ 0.318935] pci 0000:00:1d.0: bridge window [mem 0xc4100000-0xc41fffff]
[ 0.318940] pci_bus 0000:00: Some PCI device resources are unassigned, try booting with pci=realloc
[ 2.862540] nvidia 0000:02:00.0: enabling device (0000 → 0003)
[ 2.862659] NVRM: request_mem_region failed for 0M @ 0x0. This can
NVRM: occur when a driver such as rivatv is loaded and claims
NVRM: ownership of the device’s registers.
[ 2.862662] nvidia: probe of 0000:02:00.0 failed with error -1
[ 2.862673] NVRM: The NVIDIA probe routine failed for 1 device(s).
Try booting with the kernel parameter: pci=realloc
Or maybe you have a “Above 4G Decoding” setting in bios?
Also the card is running at 4x PCIe link speed, that’s a bit low. Any setting in bios you can change that, or another pci slot available with higher speed? Check your motherboards documentation.
Edit: oops generix was faster. sorry for a mostly redundant reply.
There’s absolute no trace of a second nvidia gpu handed over to the kernel by the bios.
What’s the pci id it gets assigned to by Windows?
Please update bios.
