2x Jetson Nanos turn on with Green Light but no HDMI output - with Log Files
Hi all,
I have a few Jetson Nanos for a project we are doing, two of them work perfectly, however when I tried booting up another two of them, the Nvidia screen showed initially, then went blank. Now those Jetsons will ‘turn on’, as in the green light will light up and stay on, but I cannot get any HDMI output, and from the log files it can be seen that the Jetsons don’t boot up properly.
From our two working Jetsons I am able to assure that the SD cards are flashed and work properly, so I don’t think that can be the issue.
I have attached the log files below.
I should also mention that I have tried booting up via both the micro usb cable, and with a… I can’t remember what its called but its a direct power supply using the pins on the J41 bus - that is what I used when initially trying to boot up these jetsons.
To get the below log files I used a UART serial comm cable.
I have also tried using different SD cards, which I know work from using them on the Nanos that do work.
Thanks in advance.
Jetson Nano no.1
.[0000.163] [L4T TegraBoot] (version 00.00.2018.01-l4t-e82258de)
[0000.168] Processing in cold boot mode Bootloader 2
[0000.173] A02 Bootrom Patch rev = 1023
[0000.177] Power-up reason: pmc por
[0000.180] No Battery Present
[0000.182] pmic max77620 reset reason
[0000.186] pmic max77620 NVERC : 0x40
[0000.189] RamCode = 0
[0000.191] Platform has DDR4 type RAM
[0000.195] max77620 disabling SD1 Remote Sense
[0000.199] Setting DDR voltage to 1125mv
[0000.203] Serial Number of Pmic Max77663: 0x323f9
[0000.210] Entering ramdump check
[0000.213] Get RamDumpCarveOut = 0x0
[0000.217] RamDumpCarveOut=0x0,  RamDumperFlag=0xe59ff3f8
[0000.222] Last reboot was clean, booting normally!
[0000.226] Sdram initialization is successful
[0000.231] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.237] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.242] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.248] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.254] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.260] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.266] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.272] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.288] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.294] Platform-DebugCarveout: 0
[0000.297] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.303] Non secure mode, and RB not enabled.
[0000.307] BoardID = 3448, SKU = 0x0
[0000.311] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.314] Nano-SD: checking PT table on QSPI ...
[0000.319] Read PT from (2:0)
[0000.334] Using BFS PT to query partitions
[0000.338] PT: Partition TBC NOT found !
[0000.342] Warning: Find Partition via PT Failed
[0000.346] BoardID = 3448, SKU = 0x0
[0000.349] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.353] Nano-SD: checking PT table on QSPI ...
[0000.358] PT: Partition TBC NOT found !
[0000.361] Warning: Find Partition via PT Failed
[0000.366] Error is 1
Jetson Nano No.2
.[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-e82258de)
[0000.130] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.138] Power-up reason: pmc por
[0000.141] No Battery Present
[0000.144] pmic max77620 reset reason
[0000.147] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 0
[0000.153] Platform has DDR4 type RAM
[0000.156] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x1b2165
[0000.172] Entering ramdump check
[0000.175] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0,  RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.188] Sdram initialization is successful
[0000.192] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.204] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.210] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.269] BoardID = 3448, SKU = 0x0
[0000.272] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.276] Nano-SD: checking PT table on QSPI ...
[0000.281] Read PT from (2:0)
[0000.296] Using BFS PT to query partitions
[0000.302] Loading Tboot-CPU binary
[0000.330] Verifying TBC in OdmNonSecureSBK mode
[0000.340] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.347] Bootloader downloaded successfully.
[0000.351] Downloaded Tboot-CPU binary to 0xa0000258
[0000.356] MAX77620_GPIO5 configured
[0000.359] CPU power rail is up
[0000.362] CPU clock enabled
[0000.366] Performing RAM repair
[0000.369] Updating A64 Warmreset Address to 0xa00002e9
[0000.374] BoardID = 3448, SKU = 0x0
[0000.377] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.381] Nano-SD: checking PT table on QSPI ...
[0000.385] Loading NvTbootBootloaderDTB
[0000.452] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.523] Bootloader DTB Load Address: 0x83000000
[0000.528] BoardID = 3448, SKU = 0x0
[0000.531] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.535] Nano-SD: checking PT table on QSPI ...
[0000.540] Loading NvTbootKernelDTB
[0000.606] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.679] Kernel DTB Load Address: 0x83100000
[0000.683] BoardID = 3448, SKU = 0x0
[0000.686] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.690] Nano-SD: checking PT table on QSPI ...
[0000.696] Loading cboot binary
[0000.812] Verifying EBT in OdmNonSecureSBK mode
[0000.854] Bootloader is corrupted!
[0000.857] Error in NvTbootLoadBinary: 0x14 !
[0000.861] BoardID = 3448, SKU = 0x0
[0000.864] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.868] Nano-SD: checking PT table on QSPI ...
[0000.873] PT: Partition RBL NOT found !
[0000.876] Warning: Find Partition via PT Failed
[0000.881] Error is 1
jetson2_green_light_on_no_display_with_2ndSDcard.txt (2.0 KB)
Only flashing the board with sdkmanager can bring it back in such situation.
Use the error log as keyword and search the forum and you will kind some posts about it.
Is there any straightforward way to do this (download and run the SDKmanager) with a Windows computer?
And thanks for your help
Sorry that only ubuntu host is able to do that.
Hi, thanks for the response. Sorry if this is a naive question, I’m not the most experienced here, but would an Ubuntu VM on a Windows 10 laptop (with Intel core i5 8thgen) work? That’s what I was hoping to try tmrw?
Unfortunately, VM is not supported well either.
We do have lots of flash problem comes from user’s VM. So also not recommended.
Oh right, sorry to hear that.
Not something I’m familiar with but have come across, does dual booting work?
Yes, dual boot can work. But please have enough disk space on your linux.
