Hello everyone,
I’ve recently switched to Fedora Silverblue from NixOS and Manjaro before that. On Manjaro, my 3090 was working fine in the eGPU. On Silverblue, it seems like no matter what I try I cannot get it working. It should be noted on Manjaro I had to use the open version of the module. The non-open version just would not work.
Things I’ve Tried:
- I’ve installed the drivers from RPM fusion.
- Tried kmod-nvidia with and without the X11 driver and X11 cuda driver.
- Tried kmod-nvidia-open with and without
nvidia.NVreg_OpenRmEnableUnsupportedGpus=1and with and without the X11 driver and X11 cuda driver.
- Tried both Wayland and X11.
- Made sure everything was updated including the BIOS.
- Made sure secure boot was disabled.
- Read everything I could possible find.
I am having the issue where everything except nvidia-smi can see the GPU.
$ neofetch gpu
gpu: NVIDIA GeForce RTX 3090
gpu: Intel Alder Lake-P
$ lspci | grep NVIDIA
04:00.0 VGA compatible controller: NVIDIA Corporation GA102 [GeForce RTX 3090] (rev a1)
04:00.1 Audio device: NVIDIA Corporation GA102 High Definition Audio Controller (rev a1)
$ lspci -k | grep -A 2 -E "(VGA|3D)"
00:02.0 VGA compatible controller: Intel Corporation Alder Lake-P Integrated Graphics Controller (rev 0c)
Subsystem: Device f111:0002
Kernel driver in use: i915
Subsystem: eVga.com. Corp. Device 3982
Kernel driver in use: nvidia
$ lsmod | grep nvidia
nvidia_drm 94208 0
nvidia_modeset 1556480 1 nvidia_drm
nvidia_uvm 3493888 0
nvidia 62656512 14 nvidia_uvm,nvidia_modeset
video 77824 2 i915,nvidia_modeset
$ nvidia-smi
No devices were found
dmesg is showing this:
[ 26.102540] NVRM: GPU 0000:04:00.0: rm_init_adapter failed, device minor number 0
[ 26.102852] [drm:nv_drm_load [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000400] Failed to allocate NvKmsKapiDevice
[ 26.103044] [drm:nv_drm_probe_devices [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000400] Failed to register device
Any help would be greatly appreciated. I’m happy to provided anything else that is needed.
Thank you.
Also,
I have attached my bug report.
nvidia-bug-report.log.gz (307.9 KB)
