On my macbook pro 2010 retina, the HDMI port hasn’t worked in a long time in linux. It detects the display but doesn’t send a signal out to the display. The DisplayPort ports work. The HDMI port works in windows and with the nouveau driver. I tried some different kernels and driver versions to see if I could pinpoint when the regression happened. I could only narrow it down to 340 series → 390 series change.
system: MacBookPro10,1 (A1398)
processor: Intel(R) Core™ i7-3615QM CPU @ 2.30GHz
display: GK107M [GeForce GT 650M Mac Edition]
Works: (linux 3.2.0-99-generic)
340.106 (2018-01-16)
340.107 (2018-06-06)
Doesn’t work: (linux 4.15.0-39-generic)
415.25 (2018-12-18)
410.78 (2018-11-15)
410.73 (2018-10-25)
410.66 (2018-10-16)
390.87 (2018-08-27)
Doesn’t work: (linux 3.2.0-99-generic)
390.87 (2018-08-27)
390.67 (2018-06-05)
390.77 (2018-07-16)
390.25 (2018-01-29)
390.12 (2018-01-04)
396.24 (2018-05-02)
384.130 (2018-03-28)
I can’t get 340.107 to boot into a newer kernel but I will update the post if that works or doesn’t.
Thanks for the info. I tried the solutions there but it’s still not outputing…
codyw@cody-macbook:~$ xrandr |grep ' connected'
HDMI-0 connected 1920x1080+0+60 (normal left inverted right x axis y axis) 477mm x 268mm
DP-2 connected primary 1920x1200+1920+0 (normal left inverted right x axis y axis) 331mm x 207mm
Update: Still no HDMI output with the new 410.93 (the monitor is still detected)
(I saw “Fixed a bug that could prevent display detection from working on displays connected to some notebook docking stations.” in the release notes but it did not solve my problem.)
You have a mismatch of glx module (1.18) and xserver (1.19), you should reinstall the xserver package.
The nvidia-bug-report.log is empty, not helpful. I suspect you’re using Ubuntu 16.04, did you try to run with a xorg.conf?
i.e. add nogpumanager kernel parameter, then create an /etc/X11/xorg.conf
Thanks for the info. Sorry for the delay responding, I wiped out my bootloader installing ubuntu on a USB drive :)
Anyway, I installed a fresh Ubuntu 18.04 and fully updated it. Installed 410.93 and ran startx with logverbose 6 and got a proper nvidia-bug-report.log:
Still the display is detected and enabled in nvidia-settings but no output to the screen and no error in the log file.
I also tried adding ‘nogpumanager’ to the kernel arguments and created the xorg.conf you supplied but still no output :(
(The same kernel/port/cable/monitor works with the nouveau driver)
Driver Result
nouveau works, but only from boot (can’t hotswap)
340.108 works
390.132 detects HDMI monitor and extends desktop, but as before doesn’t send a signal to the monitor (monitor goes to sleep)
418.88 same behavior as 390.132
440.44 same behavior as 390.132
If I get a chance I’ll run nvidia-bug-report with the different drivers and try and find what is different.
