4G modem/WiFi dongle
Anyone managed to connect a working WiFi AND/OR 4G modem USB dongle to the Xavier ?
If so - which model and drivers you used ?
I am aware of the intel M.2 solution, I am looking for a USB dongle.
Thanks !
Hi dannykario,
You can reference our supported component list:
[url]http://developer.nvidia.com/embedded/dlc/jetson-xavier-supported-components-list[/url]
How is this marked “Solution”?! The “component list” is basically empty, no wifi dongles listed at all.
Agreed, I am also looking to connect a SIMcard to the Jetson to provide 4G connection, however am not able to find a compatible dongle
as the topic is named
it implies that / stands for logical OR
so that the supported component list addresses at least the latter part of the concern - specifically it lists explicitly WiFi solution.
For 4G you may start a separate thread in the forum.
I will use huawei e8372 LTE USB into my Xavier NX but I don’t know how to do, and is it supported by NVIDIA? In the list you put , It doesn’t show anythinng about it.
Hi tugbakara,
Please help to open a new topic. Thanks
