Does AGX Xavier support USB LTE module connection?
I’m trying to using USB LTE module on Jetson AGX Xavier dev kit. My connection was not stable(web surfing is fine but cURL library in C++ codes doesn’t work) so I contacted manufacturer and got an answer that they don’t support linux. So I started to find other USB LTE modules. While looking for other models, I read some articles saying that support for LTE modules is not sure on AGX Xavier.
So what I want to know is, can I use USB LTE modules which support linux in AGX Xavier? Anybody using USB LTE module on AGX Xavier?
Thank you.
The USB LTE module should work, you may refer to below search: Search results for 'LTE usb #jetson-embedded-systems:jetson-agx-xavier' - NVIDIA Developer Forums
