I have ubuntu 24.04 with the latest motherboard (TUF Gaming x570 with wifi) bios update, the 6.14 kernel, and the 570.124 driver. This works fine with my old 3070Ti gpu.
When I try to swap that out with a 5070Ti gpu I get a quick flash of the motherboard info on one monitor, the grub boot menu, and then the screens all go black and the gpu fans spin up to max.
I’ve tried every solution I can find online and with AI but none work.
Apologies, I missed that part.
Assuming that other subsystems work regardless of the GPU problem, you could try ssh-ing from another computer and running nvidia-bug-report.sh then.
Hello guys,
Has there been any update or good news regarding Linux drivers for the Nvidia GeForce RTX 5070 Ti?
I’ve been trying to get it working on Ubuntu 24.04 for the past 10 days without success. I’ve attempted almost every possible method—manual installs, using the latest and older drivers, but nothing has worked so far.
According to Nvidia, version 570.133.07 is supposed to be compatible with the 5070 series, but in practice, it doesn’t seem to recognize the card. I also tried older driver versions, but still no luck.
If anyone has managed to get it working or has any suggestions, I would greatly appreciate your help.
Having same issue on Ubuntu 24.04 but the 5070 Ti does work as expected on the Windows 10 side of this dual boot system.
Drivers have been installed but the card does not appear to be recognized by the operating system. Terminal access through recovery mode does work and the card is recognized in BIOS setup.
To simplify installation, I have first disabled secure boot in my BIOS. It should be possible also to do it with secure boot enabled, but then one has to deal with signing the drivers and MOK Enrollment.
Here the output of nvidia-smi
⮕ nvidia-smi
Mon Jun 23 15:39:26 2025
| NVIDIA-SMI 570.153.02 Driver Version: 570.153.02 CUDA Version: 12.8 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 5070 Ti Off | 00000000:01:00.0 On | N/A |
| 0% 38C P8 24W / 300W | 731MiB / 16303MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 3032 G /usr/bin/gnome-shell 249MiB |
| 0 N/A N/A 4814 G /usr/bin/Xwayland 5MiB |
| 0 N/A N/A 5122 G /usr/bin/nautilus 28MiB |
| 0 N/A N/A 7281 G ./launcher 26MiB |
| 0 N/A N/A 7605 G /usr/bin/gnome-text-editor 86MiB |
| 0 N/A N/A 7655 G /opt/brave.com/brave/brave 3MiB |
| 0 N/A N/A 7697 G ...1873736b243b2831076d864fd0435 202MiB |
I had very similar problems as reported on this post, but I also had problems with very slow FPS (starcraft 2 even crashed). Installing nvidia-driver-570-open and enabling nvidia-settings → PRIME Profiles → NVIDIA (Performance Mode) things are going better!
4g option is otherwise known as 64 bit PCI BAR address decoding, which is required for Resizable BAR. It’s what lets the video card map its entire VRAM space to CPU visible. Resizable BAR is often a secondary option that lets the BAR actually be resized to the largest power of two aperture that the device needs.
Sometimes, firmware doesn’t split the two options. Sometimes you get chuckleheads like MSI who call it the “cr*pt*c*rrency m*ning” option. (LOL the forum thinks I’m a spammer if I try to mention this.)
Without the mapping, all PCI devices’ memory buffers have to fit into the low 4GB of address space. This usually results in video cards mapping a 256MB block of their RAM at the start of the VRAM, then use DMA transfers to copy any other memory ranges outside this fixed buffer.
Who knew that Nvidia was also so strongly affected by this limitation? Guess we can add them to the list alongside Intel as products that absolutely require it. It’s for the best anyway.
