545.29.06 [Wayland] Glitches in fullscreen games
Current setup:
  • OS: openSUSE Tumbleweed x86_64
  • KERNEL: 6.6.7-1-default
  • DE: Plasma 5.27.10 [Wayland]
  • WM: kwin
  • CPU: AMD 3700X
  • GPU: 3060 12Gb
  • RAM: 16Gb at 3600MHz
Also i have 2 FHD monitors 1x 166Hz (DP-2), 1x 60Hz(HDMI-1)
Problem: The problem comes when gaming in fullscreen since artifacts, flickering and ghosting problems appear.
Video on YT
bump?
I suspect that to be an issue with XWayland and the game not hitting the fps matching you screen refresh rate.
This should be fixed if:
  • XWayland patches this for nvidia
  • or Wine / Proton having proper Wayland support
  • or Nvidia patches their driver for glamour to work correctly
  • or Switching to X11
  • or NVK becoming production ready and users can make use of the open source driver stack
See the attached Bug report for XWayland:
I am affected by this issue as well even by games running on 1080p@60 fps when the game gets busy doing something and therefore the fps get below 60.
I’ve been seeing this as well (specifically previous frames being rendered if my framerate drops below my monitor refresh rate), although it’s only started occurring with the 545 driver, I’m able to run 535 without issue, and the current explicit sync patches don’t seem to solve it (although I understand they’re incomplete).
Running Manjaro, GTX 1080Ti, Ryzen 7 5800X, 32Gb DDR4, Plasma Wayland, 6.6.8 Kernel
I’m experiencing the exact same issue as seen in your YouTube video. I have a 2560x1440 144Hz display and both in Plasma wayland 5.27.10 and Hyprland it shows those artifacts in games where I do not exactly hit 144 fps.
I even tried the nvidia beta 550 driver but it showed the same artifacts.
I’m running endeavourOS, rtx 2070 super, 32gb ram, ryzen 5 5600x and kernel 6.7.2.
So this is a story about somebody, everybody, anybody and nobody?
Fixes are on the way in XWayland, Nvidia drivers and Linux desktop as Wayland Explicit Sync is rolling out within the next weeks to all major projects involved in this.
This should fix the above issue.
I am using nvidia-open-dkms version 550.78, kernel 6.8.9, hyprland. Warframe is really bad with the sync issues: the flashing/syncing/glitching makes it pretty unbearable. In game is better than in menus but it is really bad.
My web browsers flicker and render weird now too, for at least the last few driver versions. That might be due to whatever Chrome/Brave is doing with their wayland/x11 flags.
555 Beta was just released which has explicit sync support for Wayland now. Try if it solves the issue.
