565 release feedback & discussion
Bump.
What about WebGL and OpenGL in X11 in overall. Is it under consideration to be fix soon? As it’s still broken in 565.
I have enabled this variable on my AW3423DW and after a poweroff and boot up the system. My monitor cannot detect output from DP nor HDMI (black screen or my monitor would enter Standby Mode) when I login into my Wayland session, it doesn’t happen when I login into X11 though . Here is a snippet of the log : Oct 25 09:34:58 architech kwin_wayland[1257]: kwin_scene_opengl: 0x502: GL_INVALID_OPERATION error generated. and are incompatible
Oct 25 09:34:58 architech kwin_wayland[1257]: kwin_scene_opengl: Invalid framebuffer status: “GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT”
Oct 25 09:34:58 architech kwin_wayland[1257]: kwin_wayland_drm: Checking test buffer failed!
Specs:
OS: Arch Linux
Nvidia Driver Version: 560.35.03
Kernel Version:Linux 6.11.5-1-cachyos-eevdf(The same thing happens on stock kernel)
DE: Plasma 6.2.2
This is my first post so please excuse any missing steps I might not have known when trying to report my problem in this forum
Thats disabled by KDE. You need to enable it manually with environment variable.
Looks like you ran into the reason they turned HDR off by default on nvidia, which is that logging in while HDR is enabled may result in no signal on certain monitors. The bug report page mentions a possible temporary workaround, which is to keep HDR off when you log in / log out and only turn it on once you’ve logged in and are in session, but it’s said to be a driver issue so hopefully it gets resolved in a future release.
For some monitors/TVs HDR is not properly saturated, but on my Gigabyte M27Q starting with this version of driver the opposite happened.
In plasma 6.2 when I enable HDR - the SDR content is oversaturated to a point when I see chromatic abberation on fonts. The saturation slider in settings does nothing.
It’s possible that your monitor has been compensating for kwin previously not working by applying it’s own gamut scaling (perhaps something like an sRGB mode in your monitor’s picture settings), so now it would be over-saturating since it isn’t needed. When you have HDR enabled, take a look in your monitor’s OSD under picture settings and make sure it’s set to Standard or some other flat setting. Edit - missed that the slider doesn’t do anything, the above might still apply but that sounds like a kwin issue.
FYI, yeah it’s fixed in Dev now, sort of.
Game started in high graphics settings, when I changed to Very high the game wants to restart. After the restart the vertex explosions were there again. So I quit the game and restarted it again, and the vertex explosions were gone again (?).
Something to consider for the next release perhaps.
Thanks, other modes did not change the result sadly. Found it to be refresh rate related. Everything over 120hz is causing oversaturation and oversharpening (on DP, HDMI exhibited problems on anything over 60hz)
Nvidia, Please also fix External monitor freezes when using dedicated GPU - #151 by dmakc which isnt wayland specific issue. Thank you!
Same with lazer for me on kde/wayland, it used to crash a few seconds later now its instant.
Intermittent system freezing still happens when multiple monitors are connected to a system using PRIME offloading and a Vulkan application is running, on both X11 and Wayland.
Any update on handling this issue would be appreciated; several workflows are broken by this bug.
Glad to report it fixed a huge issue with Unreal Engine.
Oh boy, where do I start.
Well first of all, as I already mentioned in the previous response, the Unreal Engine crash has been fixed, which is a huge thing, good job for doing that, I am truly thankful.
However, the performance impact is just unreal.
I’ll attach a video showcasing several games, all running under xwayland, performing poorly.
To be specific, a huge performance downgrade happens as you scale the game resolution up, as shown in the video.
This also applies to Unreal Engine.
Oddly enough, Firefox, Vesktop and CS2 don’t seem to be affected by this.
However, CS2 performs significantly worse compared to 560, as seen in the video, I think.
Another huge thing is Chromium straight up not displaying page content.
I attached a screenshot of YouTube below.
Important thing to mention is that this is completely rng, it sometimes happens and sometimes doesn’t, can’t reliably reproduce it as of rn.
EDIT
My system info:
NNNNNNNN              NNNNNNNN              NNNNN    nnra
NNNNNNNNN             NNNNNNNNN             NNNNN   ⎟‾‾‾‾
NNNNNNNNNN            NNNNNNNNNN            NNNNN   ⎛ : Arch Linux x86_64
NNNNN NNNNN           NNNNN NNNNN           NNNNN   ⎜ : 6.11.5-zen1-1-zen
NNNNN  NNNNN          NNNNN  NNNNN          NNNNN   ⎜💻: fish 3.7.1
NNNNN   NNNNN         NNNNN   NNNNN         NNNNN   ⎜ : alacritty
NNNNN    NNNNN        NNNNN    NNNNN        NNNNN   ⎜🖌 : OomoxRicer [GTK2/3]
NNNNN     NNNNN       NNNNN     NNNNN       NNNNN   ⎜🖼 : RicerIcons [GTK2/3]
NNNNN      NNNNN      NNNNN      NNNNN      NNNNN   ⎜🄵 : Courier Prime Code 15 [GTK2/3]
NNNNN       NNNNN     NNNNN       NNNNN     NNNNN   ⎜ : 5120x1440@240
NNNNN        NNNNN    NNNNN        NNNNN    NNNNN   ⎜🖥️ : Intel i9-9900K (16) @ 5.000GHz
NNNNN         NNNNN   NNNNN         NNNNN   NNNNN   ⎜🎮: Intel CoffeeLake-S GT2 [UHD Graphics 630]
NNNNN          NNNNN  NNNNN          NNNNN  NNNNN   ⎜🎮: NVIDIA GeForce RTX 2080 Ti Rev. A
NNNNN           NNNNN NNNNN           NNNNN NNNNN   ⎜📊: 9866MiB / 31809MiB
NNNNN            NNNNNNNNNN            NNNNNNNNNN   ⎜⌘ : Z390 AORUS MASTER
NNNNN             NNNNNNNNN             NNNNNNNNN   ⎜󰏗 : 1484 (pacman), 20 (flatpak)
NNNNN              NNNNNNNN              NNNNNNNN   ⎝⏳: 1 hour, 55 mins
  ~        09:42:12
❯ nvidia-smi
Sat Oct 26 09:42:39 2024
| NVIDIA-SMI 565.57.01              Driver Version: 565.57.01      CUDA Version: 12.7     |
|   0  NVIDIA GeForce RTX 2080 Ti     Off |   00000000:01:00.0  On |                  N/A |
| 45%   55C    P0             81W /  300W |    5794MiB /  11264MiB |     12%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                              GPU Memory |
|        ID   ID                                                               Usage      |
|    0   N/A  N/A       971      G   Hyprland                                     1601MiB |
|    0   N/A  N/A      1087      G   kdeconnectd                                     2MiB |
|    0   N/A  N/A      1124      G   alacritty                                     129MiB |
|    0   N/A  N/A      1128      G   /usr/lib/firefox/firefox                      283MiB |
|    0   N/A  N/A      1221      G   /usr/lib/xdg-desktop-portal-kde                 2MiB |
|    0   N/A  N/A      1234      G   /usr/lib/xdg-desktop-portal-kde                 2MiB |
|    0   N/A  N/A      3251      G   /usr/bin/kded6                                  2MiB |
|    0   N/A  N/A      3793    C+G   .../Engine/Binaries/Linux/UnrealEditor       3518MiB |
|    0   N/A  N/A      6827      G   ...local/share/Steam/ubuntu12_32/steam          3MiB |
|    0   N/A  N/A      7193      G   ./steamwebhelper                               95MiB |
|    0   N/A  N/A     16827      G   alacritty                                      73MiB |
  ~        15:52:15
❯ hyprctl version
Hyprland 0.44.0 built from branch main at commit 3cec45d82113051d35e846e5d80719d8ea0f7002  (Improve hyprland-session.service (8225)).
Date: Thu Oct 24 16:50:53 2024
Tag: v0.44.0-73-g3cec45d8, commits: 5372
built against aquamarine 0.4.3
Can you tell me where you found the DEV version? I don’t see any changes on github or driver list
Dev is still based on 550 so you don’t have the features of 565 or 560.
Here is the nvidia bug report from just after the crash:
nvidia-bug-report.log.gz (728.5 KB)
hopefully nvidia team an find the issue from here. I also gave exact repro steps to them a few months ago however they never got back to me. same with the spider-man vram leak.
I’ve just updated to version 565 and i got regression like before in a past version. My first monitor connected using DVI shows a black screen while second one is fine. Using 560 version all works fine. I’m using Nvidia 970 and CachyOS. Both monitors connected using the 2 DVI ports.
This is what is happening to me. A black screen and the monitor goes to disconnect mode.
Like it was not connected. I would need to go back to any other previous version for it to work.
Ubuntu 24.10 with nvidia 4090
Vertex explosions and graphical glitches in Starfield on this 565 release, probably something with DirectX 12.
