6 imx477 with jetson ORIN
Continuing the discussion from Does AGX Orin Dev Kit support raspberry pi hq camera:
As in this discussion i can see that imx477 support Jetson AGX ORIN with Auvidea J20 Board. But i want to know whether we can use 6 imx477 at a time or not, As i am planning to buy 6 camera and J20 Board but before purchase i want to clear this doubt. @OpenJeston @rmbeh578
Suppose Orin able to support 6 cameras without problem.
For this case need to implement the device tree for it.
I am not sure what you saying will Auvidea j20 will support or not if it will support 6 IMX477 camera what specific changes i need to do for device tree.
Please check below document for driver implementation.
https://docs.nvidia.com/jetson/archives/r35.3.1/DeveloperGuide/text/SD/CameraDevelopment/SensorSoftwareDriverProgramming.html
Thankyou, I will look into it for Device tree, As what i am asking apart from device tree is that Auvidea J20 is having 6-csi 2-lane ports and the imx477 is 4-lane as i can see that it is supported by Auvidea J20 but can it handle 6 camera simultaneously.
IMX477 driver also support 2 lane configure via device tree configure after J5.1.1
Of course , supported.
Did you checked it with current setup as you mentioned here Does AGX Orin Dev Kit support raspberry pi hq camera
