Thank you for your kind advice.
After entering commands you have suggested, I have seen this output:
Starting program: /home/mericgeren/deepstream_tao_apps/apps/tao_others/deepstream-heartrate-app/deepstream-heartrate-app 3 v4l2:///dev/video2 ./heartrate
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/aarch64-linux-gnu/libthread_db.so.1".
[New Thread 0x7fac6d61f0 (LWP 6070)]
Request sink_0 pad from streammux
Now playing: v4l2:///dev/video2
Using winsys: x11
[New Thread 0x7f85d851f0 (LWP 6071)]
[New Thread 0x7f855841f0 (LWP 6072)]
[New Thread 0x7f84c841f0 (LWP 6073)]
[New Thread 0x7f7ffff1f0 (LWP 6074)]
[New Thread 0x7f7efcf1f0 (LWP 6075)]
[New Thread 0x7f7e7ce1f0 (LWP 6076)]
[New Thread 0x7f7dfcd1f0 (LWP 6077)]
Library Opened Successfully
Setting custom lib properties # 1
Adding Prop: config-file : ../../../../configs/heartrate_tao/sample_heartrate_model_config.txt
Inside Custom Lib : Setting Prop Key=config-file Value=../../../../configs/heartrate_tao/sample_heartrate_model_config.txt
[New Thread 0x7f69fb91f0 (LWP 6078)]
0:00:03.659023214 6069 0x5556310e70 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary-infer-engine1> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1161> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
0:00:09.267873517 6069 0x5556310e70 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-infer-engine1> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/home/mericgeren/deepstream_tao_apps/models/faciallandmark/facenet.etlt_b1_gpu0_int8.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x416x736
1 OUTPUT kFLOAT output_bbox/BiasAdd 4x26x46
2 OUTPUT kFLOAT output_cov/Sigmoid 1x26x46
0:00:09.279795615 6069 0x5556310e70 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-infer-engine1> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /home/mericgeren/deepstream_tao_apps/models/faciallandmark/facenet.etlt_b1_gpu0_int8.engine
[New Thread 0x7f697b81f0 (LWP 6088)]
[New Thread 0x7f60c0e1f0 (LWP 6089)]
[New Thread 0x7f5bfff1f0 (LWP 6090)]
0:00:09.420759025 6069 0x5556310e70 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-infer-engine1> [UID 1]: Load new model:../../../configs/facial_tao/config_infer_primary_facenet.txt sucessfully
[New Thread 0x7f5b7fe1f0 (LWP 6091)]
[New Thread 0x7f518071f0 (LWP 6092)]
Running...
[New Thread 0x7f510061f0 (LWP 6093)]
[New Thread 0x7f508051f0 (LWP 6094)]
HeartRate model config file: ./heartrateinfer_impl/../../../../models/heartrate/heartrate.etlt_b16_gpu0_fp16.engine
Deserializing engine from: ./heartrateinfer_impl/../../../../models/heartrate/heartrate.etlt_b16_gpu0_fp16.engineThe logger passed into createInferRuntime differs from one already provided for an existing builder, runtime, or refitter. Uses of the global logger, returned by nvinfer1::getLogger(), will return the existing value.
[MemUsageChange] Init CUDA: CPU +0, GPU +0, now: CPU 931, GPU 14218 (MiB)
Loaded engine size: 1 MiB
Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
Using cublas as a tactic source
[MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +8, now: CPU 933, GPU 14227 (MiB)
Using cuDNN as a tactic source
[MemUsageChange] Init cuDNN: CPU +0, GPU +13, now: CPU 933, GPU 14240 (MiB)
Deserialization required 39052 microseconds.
[MemUsageChange] TensorRT-managed allocation in engine deserialization: CPU +0, GPU +0, now: CPU 0, GPU 16 (MiB)
[MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +1, now: CPU 933, GPU 14241 (MiB)
[MemUsageChange] Init cuDNN: CPU +0, GPU +2, now: CPU 933, GPU 14243 (MiB)
Total per-runner device persistent memory is 273920
Total per-runner host persistent memory is 26656
Allocated activation device memory of size 2029568
[MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +0, GPU +3, now: CPU 0, GPU 19 (MiB)
3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[1] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
[New Thread 0x7f3bfff1f0 (LWP 6095)]
[New Thread 0x7f3b7fe1f0 (LWP 6097)]
OutputThread facebox is 638 454 1195 1064 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
3: [executionContext.cpp::resolveSlots::1480] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::resolveSlots::1480, condition: allInputDimensionsSpecified(routine)
2: [executionContext.cpp::enqueueInternal::366] Error Code 2: Internal Error (Could not resolve slots: )
OutputThread infer result is 0
OutputThread facebox is 648 459 1187 1057 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 648 460 1193 1054 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 648 458 1195 1074 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 650 467 1200 1081 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 652 460 1200 1072 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 656 462 1189 1064 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 660 460 1184 1033 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 665 465 1179 1027 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 674 456 1170 1065 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 676 453 1176 1060 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 670 452 1177 1065 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 673 451 1178 1063 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 672 457 1168 1064 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 663 455 1154 1063 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 668 453 1153 1063 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 665 454 1147 1056 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 664 455 1147 1058 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 669 456 1181 1062 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 666 454 1170 1056 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 665 456 1150 1056 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 663 455 1155 1056 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 666 458 1156 1066 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 672 460 1170 1066 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 674 454 1173 1067 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 664 457 1156 1071 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 674 456 1164 1068 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 668 454 1150 1064 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 671 456 1170 1062 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 667 456 1156 1071 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 667 457 1159 1071 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 666 462 1136 1059 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 665 456 1154 1060 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 664 453 1154 1059 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 673 460 1168 1060 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 667 453 1153 1060 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 674 458 1167 1061 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 674 460 1167 1064 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 672 452 1178 1064 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 672 466 1150 1055 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 676 464 1169 1065 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 676 460 1169 1054 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 674 461 1157 1063 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 673 460 1155 1049 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 678 458 1165 1053 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 675 463 1165 1053 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 673 461 1157 1060 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 668 461 1156 1054 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 677 459 1167 1054 w/h 1920 1280 process w/h/pitch 1920 1280 5888 3: [executionContext.cpp::setBindingDimensions::944] Error Code 3: API Usage Error (Parameter check failed at: runtime/api/executionContext.cpp::setBindingDimensions::944, condition: profileMaxDims.d[i] >= dimensions.d[i]. Supplied binding dimension [16,3,72,72] for bindings[0] exceed min ~ max range at index 0, maximum dimension in profile is 2, minimum dimension in profile is 1, but supplied dimension is 16.
OutputThread facebox is 674 464 1166 1055 w/h 1920 1280 process w/h/pitch 1920 1280 5888 ERROR from element nvvideo-renderer: Output window was closed
Error details: /dvs/git/dirty/git-master_linux/3rdparty/gst/gst-nveglglessink/ext/eglgles/gsteglglessink.c(911): gst_eglglessink_event_thread (): /GstPipeline:pipeline/GstEglGlesSink:nvvideo-renderer
Returned, stopping playback
[Thread 0x7f508051f0 (LWP 6094) exited]
[Thread 0x7f5bfff1f0 (LWP 6090) exited]
[Thread 0x7f60c0e1f0 (LWP 6089) exited]
[Thread 0x7f697b81f0 (LWP 6088) exited]
[Thread 0x7f84c841f0 (LWP 6073) exited]
[Thread 0x7f3bfff1f0 (LWP 6095) exited]
Average fps 33.839731
Totally 50 faces are inferred
Deleting pipeline
[Thread 0x7fac6d61f0 (LWP 6070) exited]
[Thread 0x7f7efcf1f0 (LWP 6075) exited]
[Thread 0x7f7e7ce1f0 (LWP 6076) exited]
[Thread 0x7f7dfcd1f0 (LWP 6077) exited]
[Thread 0x7f510061f0 (LWP 6093) exited]
[Thread 0x7f5b7fe1f0 (LWP 6091) exited]
[Thread 0x7f518071f0 (LWP 6092) exited]
[Thread 0x7f69fb91f0 (LWP 6078) exited]
[Thread 0x7f85d851f0 (LWP 6071) exited]
[Thread 0x7f3b7fe1f0 (LWP 6097) exited]
[Thread 0x7f855841f0 (LWP 6072) exited]
[Thread 0x7fb7ff4010 (LWP 6069) exited]
[Inferior 1 (process 6069) exited normally]
and when I enter the bt
command, it prints out the message “No stack.
Could you offer your advice and guidance please?
Kindest regards.
