naoto
June 15, 2021, 3:48am
1
I’m currently using JetsonTX2/R32.2.1/Jetpack 4.2.2.
I found a issue that “control-rate” does not work properly when I execute the following GStreamer command.
gst-launch-1.0 nvarguscamerasrc timeout=10 !
‘video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080,
format=(string)NV12, framerate=(fraction)30/1’ ! nvvidconv !
‘video/x-raw(memory:NVMM), format=(string)I420’ ! nvv4l2h264enc control-rate=1 bitrate=262144 ! h264parse ! qtmux ! filesink location=test.mp4 -e
At this time, if you darken or brighten the room
The size of test.mp4 changes a lot.
Does anyone know why the amount of data cannot be fixed?
This has the same issue with omxh264enc.
And the NVIDIA development kit also has this issue.
Also, since I have already made a product using R32.2.1,
It’s difficult to use the new Jetpack from now on.
I would like to use R32.2.1 to solve this issue.
naoto
June 15, 2021, 6:23am
4
Thank you for your reply.
I have tried your patch
The issue did not improve.
Does this patch also apply to omxh264enc?
Both omxh264enc and nvv4l2h264enc did not improve the issue.
naoto
June 15, 2021, 9:48am
6
Please refer to this post and configure vbv-size :
bitrate=512kbps(512*1024=524288)
FPS:30
‘video/x-raw(memory:NVMM), format=(string)I420’ ! nvv4l2h264enc ratecontrol-enable=1 control-rate=1 bitrate=524288 vbv-size=20000 ! h264parse ! qtmux ! filesink location=test.mp4 -e
I set vbv-size but it didn’t fix the issue.
The file size changes greatly depending on whether the room is bright or dark.
It looks similar to
Constant Bitrate help - #12 by DaneLLL
500kbps is too harsh for 1080p30. Hardware encoder cannot encode insuch low nitrate when scene changes or scene is complicated. Suggest set bitrate to a larger value.
naoto
June 15, 2021, 12:12pm
8
Hi DaneLLL
Thank you for your support.
I understand that it is a problem of the bit rate and image size used.
