- Problem Description:
The Orin NX module has three USB 3.2 interfaces, but currently only USB 3.2 (Port #0) can be recognized with the same hardware configuration, and the other two ports cannot be recognized. The pin configurations for USB 3.2 (Port #1) and USB 3.2 (Port #2) are provided below. Please help to determine if additional configuration(like dtb modification or pinmux) is needed. - Pin Connections:
Figure 1: On the left are the pin configurations for the test baseboard, while on the right are the pin configurations provided in the official manual.
Figure 2: Type C interface section (same as Port #0).
Is there anyone who designs carrier boards for similar situations?
charmyoung,
Are you trying to communicate a USB pin of your Orin NX module to a HD3SS3220? (I’m trying to understand the problem).
Best,
JDiego Delgado
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
Please check the adaptation guide from Orin AGX developer guide first. How to configure the usb port are all listed there.
