We use GPIO(pin:B8, GPIO3_PS.05) as pps input capture on orin, but it can’t work.
PPS sch like this:
the yellow signal is PPS_IN and blue signal is GPIO_CODEC_INT
In ORIN Linux, run
ppstest /dev/pps0
report error like this:
and device tree config like this:
pps {
compatible = “pps-gpio”;
// pin:B8 (GPIO3_PS.05)
gpios = <&tegra_main_gpio TEGRA194_MAIN_GPIO(S, 5) 0>;
the same custom board with AGX_XAVIER module, PPS_IN works well with ppstest in Linux, but with AGX_ORIN, it can’t capture the pps signal. then what’s the difference about the GPIO pin with xavier and orin module?
according to the topic: Using pps-gpio on Orin
there’s an issue that pps fetch will timeout.
we’re still checking this internally.
then what’s the internally checking result?
kayccc
February 21, 2023, 3:02am
5
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
like topic About ORIN gpio value after rising edge said:
GPIO3_PAC.05 on Orin, but it’s GPIO3_PS.05 on Xavier.
on Orin we use the GPIO3_PAC.05 (B8, GPIO11).
xavier works well, but orin can’t capture the GPIO edge in time.
hello liu.jialu,
so, this Topic 241503 is duplicated issue, right?
please also share the Orin device tree config for using GPIO3_PAC.05.
yes, it’s a duplicate issue about the GPIO.
add bellow lines to file :
kernel_src/hardware/nvidia/platform/t23x/common/kernel-dts/t234-common-cvm/tegra234-cvm-p3701.dtsi
pps {
// pin:B8 (GPIO3_PAC.05)
gpios = <&tegra_main_gpio TEGRA234_MAIN_GPIO(AC, 5) GPIO_ACTIVE_LOW>;
system
Closed
March 29, 2023, 2:35am
11
