About super mode 40W for 20V adapter
Hi, we are using 20V ADP to fit with Jetson NX module for super mode product, but there is 5% tolerance with the 20V ADP (Max. 21V), would like to know is there any risk or concern?
To address your question regarding the use of a 20V ADP (Adapter Power) with a tolerance of 5% (max 21V) for a Jetson Orin NX module in Super Mode, we need to consider several factors, including the specifications of the Jetson Orin NX series, the implications of operating at higher voltages, and any potential risks or concerns associated with such an operation.
  1. Jetson Orin NX Series Specifications: The Jetson Orin NX series is part of NVIDIA’s Jetson family, designed for AI computing and computer vision applications. These modules are typically specified to operate within certain voltage and power consumption limits to ensure reliable and efficient performance.
  2. Voltage Tolerance and Specifications: The use of a 20V ADP with a 5% tolerance means the actual voltage supplied could range from 19V to 21V. Most electronic components, including those on the Jetson Orin NX module, are designed to operate within a specific voltage range. Operating at the higher end of this range (up to 21V in this case) could potentially lead to increased power consumption and heat generation.
  3. Super Mode Operation: The Jetson Orin NX module’s Super Mode is designed to provide enhanced performance. This mode might already push the module to its operational limits in terms of power consumption and heat dissipation. Adding a potential overvoltage condition could exacerbate these factors.
  4. Risks and Concerns:
    • Heat Generation and Thermal Management: Increased voltage can lead to higher power consumption, which in turn can cause the module to run hotter. This could be a concern if the system’s thermal management (cooling) is not adequately designed to handle the increased heat load.
    • Component Reliability and Lifespan: Operating electronic components at higher than recommended voltages can reduce their lifespan and reliability. This is because higher voltages can accelerate wear and tear on components, potentially leading to premature failure.
    • Power Supply and Efficiency: The efficiency of the power supply and the module’s power management circuitry could be affected by the higher input voltage, potentially leading to reduced overall system efficiency and increased heat generation.
  5. Comparison with Other Modules: It’s worth noting that the Jetson Orin Nano series, another part of the Jetson family, might have similar considerations regarding voltage tolerance and operational modes. However, specific risks and concerns could vary based on the design and specifications of each module series.
  6. Recommendations and Next Steps: To mitigate potential risks, it’s recommended to:
    • Consult the official NVIDIA documentation and support channels for specific guidance on operating the Jetson Orin NX module with a 20V ADP and 5% tolerance.
    • Ensure that the system’s thermal management is capable of handling the potential increase in heat generation.
    • Monitor the system’s performance, power consumption, and thermal parameters closely during operation to identify any potential issues early.
In conclusion, while using a 20V ADP with a 5% tolerance (max 21V) for a Jetson Orin NX module in Super Mode might not immediately cause issues, it’s crucial to be aware of the potential risks and take steps to mitigate them. This includes careful consideration of thermal management, component reliability, and overall system efficiency. Always refer to the latest official documentation and seek support from NVIDIA or qualified engineers if unsure about any aspect of the operation.
Hi, thank you for your reply.
We would like to know is there OVP(Over Voltage Protection) value with Jetson Orin NX series module such like 16GB & 8GB for our reference, thanks!
Refer to the Orin NX data sheet Jetson Orin NX Series Modules Data Sheet https://developer.nvidia.com/downloads/jetson-orin-nx-module-series-data-sheet
