Hello. We are getting a tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms error on a xavier nx with custom board and wanted to ask some question about rtcpu_nvcsi_intr errors. Our sensor is a ov64b in jetpack 5.1.5 with a external provided mclk.
Clock are boosted with:
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate > /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate > /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate > /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
after capture with v4l2-ctl --device=/dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --stream-mmap=0 --stream-count=1 --stream-to=frame.raw --verbose in traces we found the following errors on repeat:
trace
v4l2-ctl-1047 [002] .... 45.686858: tegra_channel_open: vi-output, ov64b 2-0036
v4l2-ctl-1047 [002] .... 45.693192: tegra_channel_set_power: ov64b 2-0036 : 0x1
v4l2-ctl-1047 [002] .... 45.693204: camera_common_s_power: status : 0x1
v4l2-ctl-1047 [002] .... 45.716346: tegra_channel_set_power: 13e10000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-1047 [002] .... 45.716350: csi_s_power: enable : 0x1
v4l2-ctl-1047 [002] .... 45.716719: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt c4
v4l2-ctl-1047 [001] .... 45.717969: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-1047 [001] .... 45.719560: tegra_channel_set_stream: 13e10000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-1047 [001] .... 45.719564: csi_s_stream: enable : 0x1
v4l2-ctl-1047 [001] .... 45.719956: tegra_channel_set_stream: ov64b 2-0036 : 0x1
kworker/2:2-122 [002] .... 45.736261: rtcpu_vinotify_event: tstamp:1923149562 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:61530742976 data:0xcd9ce50010000000
kworker/2:2-122 [002] .... 45.736263: rtcpu_vinotify_event: tstamp:1923149719 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:61530755456 data:0x0000000031000001
kworker/2:2-122 [002] .... 45.736264: rtcpu_vinotify_event: tstamp:1923149893 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:61530810528 data:0xcd9ce20010000000
kworker/2:2-122 [002] .... 45.736265: rtcpu_vinotify_event: tstamp:1923150045 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:61530822464 data:0x0000000031000002
kworker/2:2-122 [002] .... 46.240265: rtcpu_nvcsi_intr: tstamp:1937916976 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000022
kworker/2:2-122 [002] .... 46.240269: rtcpu_nvcsi_intr: tstamp:1937916976 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000020
kworker/2:2-122 [002] .... 46.240270: rtcpu_nvcsi_intr: tstamp:1937916976 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000132
kworker/2:2-122 [002] .... 46.240271: rtcpu_nvcsi_intr: tstamp:1937916976 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000120
kworker/2:2-122 [002] .... 46.240272: rtcpu_nvcsi_intr: tstamp:1938976541 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000042
kworker/2:2-122 [002] .... 46.240272: rtcpu_nvcsi_intr: tstamp:1938976541 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000040
kworker/2:2-122 [002] .... 46.240273: rtcpu_nvcsi_intr: tstamp:1938976541 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000062
kworker/2:2-122 [002] .... 46.240274: rtcpu_nvcsi_intr: tstamp:1938976541 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000040
kworker/2:2-122 [002] .... 46.240274: rtcpu_nvcsi_intr: tstamp:1938977400 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000022
kworker/2:2-122 [002] .... 46.240275: rtcpu_nvcsi_intr: tstamp:1938977837 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000044
kworker/2:2-122 [002] .... 46.240276: rtcpu_nvcsi_intr: tstamp:1938977837 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000060
kworker/2:2-122 [002] .... 46.240276: rtcpu_nvcsi_intr: tstamp:1938977837 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000066
kworker/2:2-122 [002] .... 46.240277: rtcpu_nvcsi_intr: tstamp:1938977837 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000060
kworker/2:2-122 [002] .... 46.240278: rtcpu_nvcsi_intr: tstamp:1938978683 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000022
kworker/2:2-122 [002] .... 46.240279: rtcpu_nvcsi_intr: tstamp:1938979132 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000044
kworker/2:2-122 [002] .... 46.240279: rtcpu_nvcsi_intr: tstamp:1938979132 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000040
kworker/2:2-122 [002] .... 46.240280: rtcpu_nvcsi_intr: tstamp:1938979132 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000046
kworker/2:2-122 [002] .... 46.240281: rtcpu_nvcsi_intr: tstamp:1938979132 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000040
kworker/2:2-122 [002] .... 46.240281: rtcpu_nvcsi_intr: tstamp:1938979968 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000042
kworker/2:2-122 [002] .... 46.240282: rtcpu_nvcsi_intr: tstamp:1938980426 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000024
kworker/2:2-122 [002] .... 46.240283: rtcpu_nvcsi_intr: tstamp:1938980426 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000040
kworker/2:2-122 [002] .... 46.240283: rtcpu_nvcsi_intr: tstamp:1938980426 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000064
kworker/2:2-122 [002] .... 46.240284: rtcpu_nvcsi_intr: tstamp:1938980426 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000040
kworker/2:2-122 [002] .... 46.240285: rtcpu_nvcsi_intr: tstamp:1938981266 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000044
kworker/2:2-122 [002] .... 46.240286: rtcpu_nvcsi_intr: tstamp:1938981734 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000022
From TRM we decode the errors to:
phy 1, cil 0
status: 0x00000022
bit val description
5 1 intr_cil_data_lane_sot_sb_err1_a
1 1 intr_cil_data_lane_sot_sb_err0_a
status: 0x00000024
bit val description
2 1 intr_cil_data_lane_sot_mb_err0_a
status: 0x00000042
bit val description
6 1 intr_cil_data_lane_sot_mb_err1_a
status: 0x00000044
bit val description
status: 0x00000046
bit val description
status: 0x00000062
bit val description
status: 0x00000064
bit val description
status: 0x00000066
bit val description
status: 0x00000132
bit val description
8 1 intr_cil_data_lane_rxfifo_full_err1_a
4 1 intr_cil_data_lane_rxfifo_full_err0_a
phy 1, cil 1
status: 0x00000020
bit val description
status: 0x00000040
bit val description
status: 0x00000060
bit val description
status: 0x00000120
bit val description
Our relevant DTB values for the camera mode are:
========= DTB Values ==========
width 1920
heigth 1080
pix_clk_hz 320000000
discont clk no
line_length 2200
cil_settletime 160
embedded_metadata_height 0
discontinuous_clk no
And deskew is not enable on sensor.
Configuration mode is 1920x1080 10bit with a datarate of 800mbps from sensor documentation. pix_clk is calculated as 800Mbps * 4 lanes /10= 320000000hz
Logs:
CamTrace.log (5.9 KB)
dmesg.log (2.3 KB)
With that we have the following questions:
- Why don’t we always get the
intr_cil_data_lane_rxfifo_full_err1_aerror? - How the combination of
intr_cil_data_lane_sot_sb_err1_aandintr_cil_data_lane_sot_mb_err1_aworks? are the error on differents SOT? - How can we access the data obtained during the SOT?
- Is it possible to dump the data from the FIFO buffer?
- Can NVIDIA provide a debug camera firmware for jetpack 5.1.5.? We see that one is available for 1.5.3 in Making sure you're not a bot!
