Nsight 2021.1.0. ignores offsets when multiple BLASes reference the same AABB geometry buffer with different offsets.
The screen shot shows that the geometry is in the buffer AabbSBO @0.
The offset should not be zero.
In the visualization panel there should be different eight BLASes.
Instead, the 1st BLAS is repeated 8 times (with proper transform).
Thank you for using Nsight Graphics and your feedback. I am sorry you ran into this issue. I have created a bug for our engineering team to investigate.
Regards,
