Acces GPIO register on Jetson Xavier NX module and modify GPIO02 value
Hi all,
We outsourced the development of a carrier board for a Jetson Xavier NX module. Everything work perfectly. We have a SD card holder in order to have the possibily to add external storage. The problem is that the SD card holder is not under alimentation so the company told me that : "This power supply is done through the GPIO02.
Once the OS has booted correctly, this IO must be switched to 0 and the SD card holder power supply should be triggered."
I have no idea how to do that. I can acces de desktop of the board but I don’t where to go in order to acces the registers.
Can someone help me?
Thank you in advance
hello arnaud.tullio,
you may refer to GitHub - NVIDIA/jetson-gpio: A Python library that enables the use of Jetson's GPIOs to control GPIO;
you’re able to control it via sysnode; please also check GPIO Changes session for the steps to check the GPIO number,
thanks
